P A D
Hi Mick and Richard,
Thanks fof the heads up on the sand boxes. Just looked at the instructions on line and it's clear that I have totally misinterpreted them. First up next will be getting them off to correct. I should have realised that with the brackets on the void side, that face should be on the outside. Having cut the whole of the etched sand boxes off also threw me, but what a dozy git I am. If I get them off intact and turn around they will then be more prototypical (I think) as the outer face of the boxes will be inset from the frame edge.
As to the brake hanger pivot fouling the rear compensation beam, I don't see any reference to it. The instructions mention the rod fouling the beam if you go for the partial compensation option, with fixed rear axle and front and middle compensated. Still it stands to reason that the same applies. In any case I prefer my option as the pivot rod is more robust if it crosses the frame. I had already fitted the middle one before the sand boxes so had to cut it, but will I replace it when I re-do the boxes. Happy days.
Cheers,
Cheers,
