Mick, will all these extra etches be included in the standard kit?Small update this week thus far, finished most of the chassis and it's in for primer, hopefully assemble it tomorrow for a few photos once I've cleaned some of the bright work up.
Mean while, have been catching up on art work for the extras, first off to the printers is the cab interior etch, basically a frame work to fit inside the cab to give it a more 3D effect and cover the half etch holes for the rivets etc.
It fits both the original and later V windscreen cabs, you simply remove the bits you do not require for each version, there is also a bespoke 9'-0" etch as well, both have the new tip up seat for the driver for engines later in their lives.
There's three other etches to complete;
Revised 8'-6" cab with small side windows, plus new window frames to suit.
Deflector variants, standard with Devon Belle clips, extended ones for the exchange locos and the longer ones at the front for Boscastle.
BFB wheel overlays to add to the Slaters wheels to bring the front face out closer to the rim.
MD
The revised V windscreen 8'-6" cab will be as that is a fundamental structural part that is missing and is part of the evolving upgrading as we go along.Mick, will all these extra etches be included in the standard kit?
So a quick whizz in Autocad and a new etch on it's way to PPD suitable for Slaters insulated axle boxes and independent springing. I'll also do one for the square brass slotted ones as well, both are adaptions of the original artwork so will just drop straight in.
No idea at the moment, the kit comes with, and is designed around compensation beams, that wasn't what the owner required, so rather than spend ages faffing around with addon horn guides and lining them up and generally wasting my time, I made an alternative inner chassis that is bespoke to that form of axle box for split axles.Is the idea to have all the options in one tender kit or the purchaser to select the tender kit based on the compensation/axlebox system they wish to adopt?
They probably do, which begs the question why you'd even bother to design frames for any sort of system. Beats me up spending hours designing, umpteen test etches and weeks of test builds only to have people simply throw it away.I think most serious model makers will fit what ever suspension system is their preference, they'll junk the bits they can't use and replace them.
Col.
Exactly.But when you're starting off along the kit building path you don't have a kit building personality or preferences , you just want the kit to go together and work. The tinkering, experimentation and deciding what your preferences are come later (along with additional tools and hard won experience).
And not even intentionalGroan. Gawd Mick, that was awful...
Len, I believe that's the general idea, but some would still like them included in the kit as a choice, even if they throw the other is not used.Hi Mick, you could offer the other frames etches as an extra cost to the purchaser.
Len
