A start has been made on the B1. I know that the frames on this kit - both loco and tender - are rather wide. When I built a tender for the K1 I found that I had to file the faces of the axle bushes so that the wheels would turn. For the loco the choices are to do the same, reduce the width of the frame spacers or the potential solution I am going to try: invert the axle bushes and saw/file to reduce the width. If you reduce the width of the spacers then you need to pack out the cylinders. That option is no longer possible so it will be something done with the bushes.
Here is the current state of the frames:
I think that the large spacer at the front (2 in the instructions) should possibly have had an additional fold so that the very front was vertical. That isn't present to I sawed back the overhang at the front which would otherwise interfere with the footplate. Missing at present is spacer 7, another large piece that fits between the centre and rear driver. The instructions note that it will likely interfere with any motor - gearbox fitting and will need cutting back. I have left it out until I fit the motor and we see how much space we have. There are slots in the frames for fitting, but no tabs on the spacer. There are overlays to fit but these are quite open around the axle positions and will not interfere with the bushes. Additional holes have been drilled for the pick ups.
The footplate is an exercise in origami.
This is folded from a single piece. Bending the valences down is not easy. I had scribed the fold to make it easier but found that my hold and fold is not big enough to do it and the bending bars could not hold securely. I think if I ever build one of these again I will continue to score the fold line until the valence drop off or saw the valence in two and fold in two halves, making good the joint with solder. There are overlays to add on the top of the footplate which will result in the valences being correctly offset from the edge. These overlays would also form a good base for the valences if they are removed and soldered in place.
I found that the folding and adjustment required at the front end resulted in the parts separating and had to be soldered back together. An irritation. I need to add the locating nuts and main overlays. I may also add the curved footplate parts so that the strength of teh footplate is built up.
