Heyside: 7mm L&Y, late 50s/early 60s
Hi
Thanks for the comments guys, appreciated.
Cynric. The idea has worked well, and there's very little I'd change. I like the half-etched lattice, it gives finesse, and you honestly don't notice the heat distortion, even if it's a bit of a fight at times - it certainly tests soldering skills. The thought of punching all the rivets on thicker pieces does not fill me with joy.
If I was to make a suggestion it would be to add the verticals (on the sides etch) from full etch every 6' where the stiffeners go, as once detached from the etch and while you are building it, there is only the flimsy half-etch lattice to set the height. Even then, I'm not sure that would ameliorate the 'problem'.
However, good fun, and a very acceptable outcome. Only another 120' to build now.
