Over a three week period I’ve been steadily adding details to the basic shell. A lot of that time was spent peering at photos, generally in the Wild Swan book of the Black 5s and its pictorial supplement. I found the Pipe and Rod, and Boiler Clothing drawings particularly useful to cover large gaps in the instructions.
There were no large diameter rods included in the kit but luckily I had some in stock for the ejector pipe and this side’s injector pipe - the other side is copper wire. The Clothing drawing gave me the precise location of the whistle and washout blisters. I had to make the covers for the injector pipes as the etchings in the kit bore no resemblance to the prototype. The hand rail is not yet fixed as I have to add the cap at the cab end last of all.
The smoke box door hinge was poorly cast so I filed off all detail and added scratch made bits - hinges, the bit that supports the door in the opposite side, I don’t know what it is called, and a working door handle. The handle is a tube in tube, ie the dart handle is fixed to a 0.7 id tube while within that is another tube with a 14 ba stud in its inner end and the tightening handle on the outer end. The whole screws into cross piece behind the door. I still need to add the steam heating pipe to the front buffer beam - another omission from the kit.
On this side I had to add the rocking ash pan control rod and cut down one of the lubricators to 2/3 of its original size, because that is how they were. I have added cladding bands to the firebox but not the boiler - lining transfers are sufficiently thick for them.
The loco superstructure is nearly there.
The tender is there, I think. Again the steam heat pipe needs adding at the back. I don’t fit the axle boxes and spring castings until after painting as it’s difficult to spray paint into the tiny gap above the spring. I will tin around the holes, mask off and then solder them on later.
You can see from the tender front that I haven’t found a source of invisible solder.
Ian R
