The confident assertion I made in an earlier post about being able to remove and replace the lathe chuck and wheel holder without introducing any out of true error turned out to be slightly wrong. For a reason I don’t understand the wheel holding tool did not run quite true when the chuck was replaced on the spindle. The wheel holding tool had not been removed from the chuck meantime. It was only a little bit out of true but it should have been near perfect. Not a big problem because it was easy to reface the part of the tool where the wheel sits.
The issue where, in S7, the Slaters wheel and crankpin boss projects far enough from the face of the wheel to cause clearance problems behind the slide bars was flagged up in a
DavidinAus post some time ago. David opted to take 0.4mm off the face and it seemed to work for him. Taking a close look at the prototype drawings in the Wild Swan book revealed that…
- the driving wheels measured 6-13/16” overall from front of axle and crankpin boss to inside face of rear boss
- the rear boss on the prototype wheels measured 15/16” from rear face of tyres to inside face of boss (there's no rear boss on the Slaters wheels, we'd use a washer or two on the model)
- the tyre was 5-1/2” in width
…and converting these dimensions to 7mm and doing the arithmetic I conclude that the model wheels ought to measure 3.42mm from inside face of tyre to outside face of axle and crankpin boss. The Slaters wheels measure 4.23mm. So there’s the missing clearance of 0.81mm each side. The prototype ‘as drawn’ clearance between inside of slide bar and leading coupling rod pin was a mere 11/16” , or 0.4mm in 7mm world. If the MOK kit has the slide bars the correct position (and it should have because there are parts on the S7 conversion etch specifically for this) then half a revolution and CLANG is the guaranteed outcome.
As it turns out you can’t sensibly face the axle and crankpin boss down by 0.81mm on the Slaters wheels. The inside ends of the spokes flare outwards to meet the moulded boss on the Slaters wheels to a greater extent than on the prototype. I suppose it makes the over thick Slaters wheel centres look in proportion. I’d never have noticed if I hadn’t checked, and in 0F it may not matter. It is possible to take 0.55mm off the thickness before you start to machine into the end of the spokes and the face of the boss starts to look like a starfish. If
DavidinAus got by with 0.4mm and I can manage 0.55mm then I figure I’m in with a chance provided that I have appropriate coupling rod and pin projection on the leading axle.
Mount a wheel in the holder and check that the tyre runs true. On some of the wheels you could see by eye that the axle insert was a little off true when the lathe was spinning. There's the root cause of the 'Slaters shimmy', as I've heard it called.
The first part of the job is to face off the crankpin and axle boss by 0.55mm using a sharp, tiny, pointy tool. This is the same tool described in the pony truck wheel thread somewhere above. The small point combined with a small depth of cut (0.15 - 0.15 - 0.15 - 0.1 as it happens) gives rise to small cutting forces which can be handled by the plastic spokes and which won’t upset the steel crankpin and axle inserts. A collateral benefit of this is that the moulding sink marks in the original surface of the moulding are removed and we have a nice flat boss like the prototype.
Next operation is to clean out the countersink and square axle hole with a sharp 4mm slot drill.
The 4mm bore is opened out to about 5.0mm with the tiny boring bar. The rationale here is that a boring bar will cut true to centre where a 5.0mm drill might wander a bit depending on how accurately it’s been sharpened.
The last operation differs slightly from the conversion of the pony truck wheels previously described. Scaling from the drawing, the prototype driving axles are about 9” diameter where they project from the driving wheel boss. That’s 5.25mm in 7mm scale, or 5.2mm for convenience. So the outer end of the axles must be 5.2mm in diameter and the bore in the wheel insert must be a gentle push fit onto the axle. For the pony truck wheels I’d made the axles to the required diameter and bored out the wheels to fit. That wasn’t straightforward as I couldn’t measure the bore accurately and had to take tiny cuts with the boring bar and keep trying the axle fit. I did it the other way round on the driving wheels. The wheel inserts are all reamed out to 5.2mm (I have a 5.2mm machine reamer) and the axle will be machined to fit the wheel. It is easier to measure the axle diameter accurately than the wheel bores and we'll get to the finished size faster and with more confidence, and since there are 8 axle ends to do so that’s a worthwhile time saving. The 5.2mm reamer works nicely through a 5.0mm bore.
With a bit of organisation it took me about 15 mins to do a wheel, so in about 2 hours one evening all the wheels were done.
Before and after...
..and all done...
Suppose I'd better make the axles next. This also makes me think about balance weights, which in turn means I need to decide which locomotive I'm actually modelling, which in turn might have consquences further downstream. I fancy a late inhabitant of the mighty 18A Toton, mid sixties, last knockings of steam on the Midland main line and I was a kid in short trousers growing up nearby. My brother reckons he remembers seeing 8Fs on the low level approach through the old Long Eaton station behind the Co-op car park. Must have been' 64 or '65 or at a push '66.
