"Obtain a running chassis" - part 5 - cylinders, motion bracket and connecting rods
Ian_C
Some more assembling of parts made earlier and some more clearance challenges.
While trial fitting the cylinders to the chassis the purpose of a couple of mystery parts on the etch was discovered. The etch actually had them labelled as cylinder spacers but I hadn't come across them in the instructions so had left them off pending enlightenment. They fit directly to the rear face of the cylinder sub assemblies and fill the gap between the chassis side plate and the cylinders. The value of that became obvious when fitted the cylinders to the chassis with screws for the first time. Without the spacer the chassis and cylinder backs bend when you attempt to tighten the screw. The spacer fills the gap and allows the screws be tightened properly.
With cylinder assembly and motion bracket assembly fitted to the chassis they lined up very well and the ends of the slide bars needed only a very small adjustment to contact the pads on the motion bracket. I have noticed on the prototype that there are sometimes packing shims between slide bar ends and motion bracket. MOK 1 - Crewe 0. The drop link can be soldered to the cross head. The slide bars can then be soldered to the motion bracket. Note that when cylinders and motion bracket are joined this way the cross head becomes captive, the cross head nut not being able to pass behind the motion bracket, and if the connecting rod is permanently attached to the cross head then that also becomes part of the assembly. Make sure all the work on these parts is complete and that cross heads slide easily before joining cylinders to motion bracket.
Anticipating a struggle for clearance behind the cross head I made sure the connecting rod..errr..connection did not project beyond the back of the cross head. The inside end of the rod was filed down a little to reduce the thickness and a small washer was turned up to go over the connecting pin cast into the back of the cross head and soldered on. The pin was filed down flush with the back of the cross head. On my cross head castings the rear flange that engages the inside edge of the slide bars was already quite thin so there was no opportunity to thin it further in pursuit of clearance. We're looking for every small bit of clearance we can gain, so worth looking to see if you can scrape a bit off the back if you're working in S7.
With the assemblies complete they can be fitted back on the chassis and the connecting rods put on the driving crankpins. More clearance problems, but not where I'd expected them. There was a sliver of daylight between the leading crankpin nut and the back of the cross head with the leading axle over at maximum side play. Same on both sides and somewhat of a relief. Reminder - to get this result in S7 you need:
The real clearance issue was between connecting rod and the coupling rod joint between axles 1 and 2. It turns out that the side play I'd provided on axles 2 and 3 allows the connecting rod to move across enough to strike the coupling rod joint nut.
Having run the chassis in a little prior to this with just the coupling rods fitted I thought I'd accurately measure the axle side play I actually ended up with as opposed to what I'd calculated I'd end up with (earlier post). Turned out that I had more side play on all axles than I'd aimed for, and that presented the opportunity to reduce the side play on axles 2 and 3 slightly. Back to the CAD drawing board and taking advantage of the actual side play on axles 1 and 4 (that I'd assumed to be zero for the purposes of constructing the geometry originally) I found that I could put spacers behind the wheels on axles 2 and 3. For what it's worth I ended up with 0.16mm spacers on axle 2 and 0.44mm spacers on axle 3. Taken together that still gives enough accommodation to negotiate a 6 ft CL radius curve with a tiny bit to spare (in theory anyway - yet to be proven!), and just gave some clearance behind the connecting rod to miss the coupling rod joint. A benefit of having a lathe is that it's the work of a few minutes to turn up spacers of any size you require, and yes it is possible to part off spacers 0.16mm thick.
And here's Mr Stanier's 0-8-0. Look's like I'm getting somewhere.
One observation, at maximum piston stroke the end of the cross head just leaves the parallel portion of the slide bars adjacent to the motion bracket. The motion drawing on page 54 of the wild Swan book shows that the prototype does a bit of this too!
- minimum sideplay on leading axle, there'll always be some but as little as you can engineer
- reduce the projection of the driving wheel bosses to scale thickness, Slaters wheels being fatter than scale in this respect (earlier post)
- counterbore the leading coupling rod and recess the leading crankpin nut, you'll need to be more or less flush with the face of the rod (earlier post)
