I think the time is right to take a look at the upper works. The first challenge is to work out how all the DCC stuff is going to fit inside.
The firebox is largely occupied by the motor and gearbox so the DCC decoder and the speaker has to fit in the boiler and smokebox. I'm new to this DCC thing so it took a bit of research to figure out what I'd want to fit. I ended up with a Zimo MX696S decoder loaded with the Digitrains Zs003A Activedrive Stanier 2 cylinder sound profile, and the speaker(s) are twin Zimo sugarcubes in a bass reflex enclosure. There are so many speaker types available and so many different points of view regarding installation that I'm not 100% sure that this is the best solution. Fingers crossed that it'll work OK. Because I didn't want to be soldering directly to the decoder pins I've added the screw terminal connector board to the decoder. That makes it quite a big lump but it will fit in the boiler ...just...with some modification.
I puzzled a bit about how, if the speaker was installed in the boiler, any sound would escape to the outside world. The speaker went in the smoke box because there really wasn't anywhere else in the locomotive for it go. I didn't want to put the speaker in the tender because I wanted the noise to come from the prototype noisy end. There's a chimney hole that I can leave open, and I made a big hole in the bottom of the smokebox and some slots in the smokebox saddle. Hopefully enough whooshing and clanking will escape.
The speaker is quite long but slim enough to fit neatly down the centre of the smokebox. The DCC decoder would fit in the boiler in theory, but couldn't be inserted due the the boiler former rings at each end that shape and stiffen the boiler etch. The boiler former rings are plenty big enough to cope with some material removal to open up the hole. Marked out with callipers and the unwanted material easily removed with a carbide burr in a mini drill and tidied up with a file and emery.
As things stood the upper works were very rear heavy due to the cast firebox and the hefty brass backhead. The DCC decoder and the speakers don't weigh much at all. The challenge was to find enough space for ballast up front to balance the loco without getting in the way of the DCC decoder and speakers. The solution was to make some lead weights to fit in either side of the smokebox alongside the speaker but not blocking the passage of sound. To get the most weight in the space available and make a tidy job I decided to cast some lead weights to match the smokebox.
Simple enough ...
Make a mould from wood to match the internal diameter of the smokebox plus a few mm to machine off. A handy offcut of oak was used. Marked out and roughly plunge cut with an end mill to quickly remove most of the material...
Finished off in the lathe to the internal diameter of the smokebox, plus a few mm for cleaning up the weight...
Enough lead flashing was cut into small pieces to fill the mould with a bit to spare. The lead was melted in the bottom of an old WD spray can held in the vice and heated from below with a blowtorch. The dross was scooped off the top of the melt with an old teaspoon and the lead was poured steadily into the wooden mould. As you might expect there's a lot of smoke and bubbling as the wood chars, and the top sinks as the lead cools and contracts. IOSH Managing Safely head on for a minute here - it's dead easy to cast lead weights like this but some sensible precautions:
- Don't have any water or fluid anywhere near the molten lead and certainly not in the mould, a shower of molten lead isn't a 'good thing'
- I'd suggest decent gloves and eye protection are a minimum requirement
- Lead is toxic so don't breath in any dust or fumes from the handling or casting process - I worked near the wide open workshop door - and scrub hands afterwards. You might want to wear a suitable face mask if you can't work in open air.
- Carry out the work in an area where any spills of molten lead fall on a surface that can resist, such as concrete or tiles
Here's the cast lump after removal from the mould. No taper in the mould and a relatively rough surface, so it took some persuading to come out...
The cast lump was cleaned up to the smokebox diameter in the lathe. To say the lead was free cutting would be an understatement...
Slices were cut off the lump for the smokebox weights and another 'spare' to sit in the bottom of the boiler under the DCC decoder if I needed more weight to balance up. The slices were tidied up and the edges reduced with a file so that they would fit through the smokebox former rings...
And here's how they fit in the smoke box, leaving room for the speaker. They'll be epoxied in when the boiler assembly is complete and before the smokebox door is fitted.
The last job was to work out exactly how much weight was needed to balance the loco. No messing around with masses and moments and maths, all done empirically. The footplate was supported on a plank of balsa wood (negligible mass) and the upper works were placed in position on the footplate with the smokebox weights in situ. I wanted the loco to be evenly balanced about the centre of the driven wheelbase and that position was marked on the footplate. The whole caboodle was supported on some MDF blocks and a length of wire was placed under the balsa at the required centre of mass. Considering the mass of the firebox casting and the backhead I was surprised that the smokebox weights made it front heavy (but having them that far forward does help). The length of the smokebox weights was gradually reduced until the whole thing balanced on the wire.
For the record, the assembly shown above weighed 562g when it balanced. When added to the 'undressed' chassis the combined weight is 840g. When the cylinders and motion are added along with the remaining etched and cast parts on the boiler and cab I reckon it'll end up around 1,000g. Being new to 7mm I've no idea what the norm is, but that feels about right to me. It would be possible to add even more weight but I don't think it's needed.
