The tank has enrolled in a weight-loss programme. I'll report back in due course.I think I'd go with Nigel's take on it.
And put that tank on a diet.
The revised width looks good. My reading of the Nantmawr drawing is that it shows a large radius curved top on the tank. The handrails are mounted near the edge of the curved top. The photograph used by AR Bennett when producing his drawing may not have shown the tank top clearly so it too could have had a segmental arched top to the tank. Curved steel needs less support than flat and it would look a bit more elegant than a Neilson or Barclay box tank.I've taken about 2.5mm off each side of the tanks. What do you reckon?
View attachment 231934View attachment 231935View attachment 231936
I'm not going to round the top edges over, as the sister locomotive sports a squared off tank.
The 'adjustments' I made to the tank mock-up yesterday were carried out quite quickly just before dinner. My rumbly tummy may have diverted my attention from accurate Plastikard pruning!To my untutored eye it looks more in proportion. Is it a trick of the camera or are the two sides uneven (as in one sticks out further than the other)?
Nigel
I'm 50/50 on the shape of the tank. Sister locomotive 'Liverpool' sports a very squared off tank, but I agree that 'Nantmawr' has a slightly curved edge to the top. The Plastikard mock-ups will continue!The revised width looks good. My reading of the Nantmawr drawing is that it shows a large radius curved top on the tank. The handrails are mounted near the edge of the curved top. The photograph used by AR Bennett when producing his drawing may not have shown the tank top clearly so it too could have had a segmental arched top to the tank. Curved steel needs less support than flat and it would look a bit more elegant than a Neilson or Barclay box tank.
The drawing is based on a photo which sadly I've not been able to track down. So yes, it's quite likely the producer of said drawing may have not got it quite right.The drawing on which you have based the loco shows a tank with rivets right at the top of the side so presumably flat top, but the height of tank over boiler looks smaller than your mock-up.
Is the consensus from the above discussion that the producer of the drawings did not capture the true shape / proportions of the tank?
Boulton’s creations / adaptations were in the main one-offs.
This is one of the great things about being able to tap into the minds of Western Thunderers: A different perspective!I was thinking the Nantmawr drawing shows something more like this-
The round corner looks a bit modern, although maybe I am just thinking of Manning Wardle with their similar shaped tanks which started with sharp arris between top and sides, then later the designed was modernised to rolled top into sides.
That looks far better than my interpretation. I shall mock something similar up and see how it looks. Thank you @Overseer Boulton is known to have been happy to have his bookkeeper spend hours lining out locos in ornate schemes so running a thin iron sheet through some rollers would not have been a problem. Not actually relevant in this case as Isaac Dixon (and Nantmawr) were built by Hughes & Co. Boulton bought Isaac Dixon secondhand and hired it out.On the other hand - if you were Isaac Watt Boulton would you want your men to spend extra time creating a tank with a hint of finesse when a basic square tank would suffice?
Very kind of you John. I think if you could see it close up and personal, you might have a bit of laugh about some of my dubious construction methods. I wonder if in a previous life I could have been working at Boulton's Sidings!I think it looks fabulous
