Dave Holt
Brian.
Although I pressed out a few rivets, on plain sheet, using a scriber, where half etched holes are provided on the back of etched parts, I normally use a rivet embossing tool which is a length of threaded bar, with adjusting nuts and a blunt point at the bottom, and a weight that is raised to the upper nut and allowed to drop, the shock load impressing the rivet. Using this ensures the same load is applied to every rivet in a pattern, so giving consistent indents. Sorry, i can't remember who I bought it from - might have been London Road Models or the late lamented, and much missed, Eileen's.
This is what it looks like.
Not a huge amount of work on the loco but quite transformative, I think. The rivetted smokebox wrapper has been fitted and trimmed to clear the loco frames. I was rather pleased that the wrapper length that I calculated for the key-hole shape proved to be accurate within a fraction of a millimetre.
The bottom of the wrapper will be hidden behind the top portion of the frames, which are the subject of further etched work.
Dave.
Dave.
