Hi,
My attention has now turned to the engine. Because the footplate is built on a cradle to which the valances are attached, the body can be built without the necessity of building the chassis first. I have got to the stage of removing the cradle and attached most of the detail up to the dreaded (just because of the sheer number) lubricators and piping.
Splashers, sandbox fillers and brackets:
Hinge pins are 1.5mm lengths of copper wire!
The front footplate:
It's a bit difficult to get in to clean it up as fully as I would like, so I have brushed some surface conditioner over it which accounts for the slightly pinkinsh tinge. I have attached the lower part of the smoke deflector to the right side, the rest of the deflector will be detachable - more on this later.
Rear of the footplate, with overlay for the firebox bottom:
And the underside of the exquisite buffers. You can see the mechanism for avoiding rotation of the oval buffers - a slot in the buffer and a pin in the base.
