It's slowly getting there
The splashers, well, the outer face has nice little slots in the footplate for the tabs to fit in, they are correct at 6 mm from the rear edge, but, the splasher top is only 5 mm wide The footplate has a nice little half etch recess at each end for the splasher brackets, again only 5 mm wide.
So, chore #1, fill all the footplate half etch recesses with 10 thou shim, then make all new wider splasher tops and finally new fixing brackets....not yet done, I still have to add the splasher rears to enclose the driving wheels, but I knew I had to do that before I started the rest.
Frames, these have nice half etch dimples for pressing the rivets out and very helpful half etch markings for the variations in frame lightening holes, problem is, you can see some of this under the boiler, so a new inner skin was made to cover all that up and then it was obvious that I'd need some horn guides etc. For no other reason other than I can, I made some new ones, I have got some hobby horse ones on order but I'll keep those for a later date as I'm moderately happy with these.
The scrap etch bin has grown from previous attempts but finally I have a workable solution, read, if you do something enough times you'll get it right once in a while!
There's no inner skin behind the aft stretcher which leaves a small gap at the top of the horn guide, I'm fairly sure this area is almost invisible once the boiler goes on so may just opt to fill the small gap with 2 part epoxy and have a slightly thicker base plate. In hindsight if I'd thought I'd be doing this now when I started out, then the whole frame area around the drivers would have had a new inner skin, rather than the patch work I have now, none of this helped by the previous builder cutting out all the axle holes.
Still to do, well, the same on the other side, then some splasher rears and pseudo brackets, a new inner cylinder casting, or at least some sort of rough facsimile, some more stretchers and plate work and some of the larger pipework and some axle boxes to cover the hornguide rear face, then I'll see how that looks before doing any more in there.
Before
After
Most of the hornguide is brass but I gave up trying to solder in the side fillets.....more scrap brass in the scrap bin!..... and had about given up (hence order to Hobby Horse...which are not strictly right for an A3 or any of the other Pacifics I've looked at truth be told) and begun to consider making them out of Plasticard when it struck me, I only need to make the fillet from Plasticard and glue in with 480, it's not load bearing but the adhesive is so good you can trim the Plasticard afterwards and I've not had one break off yet. Once painted I don't think I'll notice the difference, especially down in there.
Before
After
