Well the A3 crawls along at a glacial pace, more to do with the bits I'm adding and re adding than anything else. A while back I mused there must be some point where it would be better to stop and begin again afresh, I think I passed that point weeks ago, but being bloody minded I'm determined to grind on.
We left off with some horn guides and inner frame skins, well the other side was finished off and splasher inners added, not trailing as they are a different shape and need the splasher cover trimming to suit, those will come later after a few stiff drinks!
I also added a dummy middle cylinder which will require a few basic details to break up the slab face. New intermediate sandboxes were also fabricated but soldering them in was a painful, even at 80W and 400°C solder just did not go in the seam, so I glued the drivers side in with 480....I'm using that a lot now as I'm rapidly exceeding my soldering skills more and more often.
I also added Hobbyhorse springs, complete waste of money, wrong size, wrong shape and bleedin great holes in them to be screw fixed, very shortly I'm going to be testing the strength of the 480 adhesive trying to get them off, but only after I have found better ones. I'm hoping Ragstone at Kettering offer something better, if not the right size (I have an inkling they are all 4'2" springs) then at least the right shape hangers and fixings and preferably in brass too! The shorter sized ones I can cut back easily enough, I should of done it with these, I knew they were too long before fitting and thought the extra 5mm wouldn't be an issue, talk about putting one foot on top of the other and shooting both with one bullet!
The next stage was some light front end work, cast sand boxes went in fine and I've added the massive cylinder fixing flanges fore and aft of the outside cylinders, the kit has tiny hinges for inspection covers but these massive plate work fixings are missing? I was then going to add the bogie splashers and noted a problem, the leading one goes almost all the way around the frame opening, you can see the half etch to locate it, problem is, the real thing doesn't and stops at about 3 min to 12, meaning a half etch gap to fill later.
The rear one I think does go all the way over, but I've yet to find one good photo that proves this so they're both on hold. I've looked through all my books and cannot find any photos where the leading one is so long, not A1, A10 or A3.
Simple side view, little bit of work at the rear end on the Cartazzi axle, I used the kit castings, not perfect but passed muster for what is an ever lowering set of standards as the model progresses. Of note here is the intermediate sand box, it's too far forward by 2.5mm, cast springs too big, and the front spring is too far back by 2.5mm, which means that the 4.5mm stretcher that's supposed to fit between the sand box and leading spring hanger....can't!
Overall view, added some supports for the middle slide bar and will add a pseudo slide bar in there at some point as a light blocker, I also need to add some of the larger pipework in there as well....when i can find more accurate details.
You can just see the nice half etch hinges on the footplate covers, it would be nicer if they covered the half etch place holder so nicely supplied on the footplate, they don't, so the hinges have a nice little moat around them.
Still to come, bogie stretcher, combination lever stretcher, brake cylinder stretcher and a whole new smokebox saddle, the kit cast one is just wrong and it's cast white metal, which despite all my ham fisted attempts just will not solder, which is doubly frustrating as I built several white metal 4mm kits 20 years ago and they all still in one piece!
I'm hoping the A1 loco will be better as it'll be a newer kit so should fit better, the tender certainly didn't offer much resistance, but I am wondering what the Princess Royal and Jubilee will be like. I don't think it's all the kits fault, just my expectations seem to exceed reality more and more and I'm not even into basic fine detailing yet.
