Indeed you do, the buffers will all come out again to have the heads blackened and the bit of thread at the back. The nut being brass I've never managed to blacken well, even with the pukka stuff, so it'll get a good dose of black etch primer to make it scratch resistant and then three days later a full matt black coat.I spy with my little eye…. something that looks suspiciously like a brass nut on a buffer stem?
drop of Birchwood Casey?
sorry!
Thank you.Just standard Slaters out of the box.
Stunning model Mick, absolutely stunning.Lets start again in the right thread![]()
First of the Bulleids is back up on it's feet and rolling nicely. Next step is all the details and internal parts.
I've decided to go with micro magnets to hold the smokebox door closed, though just the small amount of paint that's got in the hinges is enough friction to hold it closed quite well.
That is a cracker Mick, well done
kind regards
Cheers, still a long way to go as yet, lots of little details to add now, pipework to clean back, smokebox interior and cab interior, then it'll start to look better.Stunning model Mick, absolutely stunning.
Jut for interest, how does the live steam get to the inside cylinder of an as-built engine?
That’s correct, three pipes on the rebuilds, four on the originals. The cente cylinder ones are approximately half the bore of the corrugated ones for the outside cylinders, hence two of them to get the same volume.From the RH connection on the superheater header to the inside cylinder valve chest (non-corrugated), just visible in Mick's photo.
Dave.
Oh, and seemingly from the LH end as well. Only the three pipes on a re-build.
That is looking like the basis of a very a very decent wheel.My apologies for jumping on this thread again but I am not sure where else to put this.
We started discussing my 3D printed resin centred Bulleid wheels here:
7mm - Mickoo's Commercial Workbench
Superb quality and detail, what more can you add to any model? seen or unseen, A complete BLP along with the smokebox detail. There's actually quite a lot more ;) Some you cannot due to scale and practical considerations and the rest would require a lot more rebuilding/hacking of the core kit...westernthunder.co.uk
and progress continues. We have now produced a cast iron version from 3D printed waxes as shown below. Can anyone recommend a 3D printing resin for producing waxes on my Phrozen mini 8K or similar? More importantly can anyone recommend someone able to produce the waxes from my CAD in quantity and at a reasonable price.
The castings are designed to take an etch for the front plate similar to the Finney7 ones.
John Walker
Giesl, couple of niggles in the roof, so some changes and another print on it's way with revisions and some tweaks to the machine settings.
The petticoat I can only do when I have the casing for Spitfire (test pig) done, then I can align everything and check gaps etc.
A lovely piece of work. I remember years ago seeing an A3 built by John Edgson, featuring an opening smokebox door, run in to the Barnet Club’s Peterborough station layout: it stopped quite quickly and the smokebox door flew open. So I would definitely go with the magnet.Lets start again in the right thread![]()
