Small update on the current BLP, brake gear done, always best to do that when you're in the right frame of mind....spawn of Satan.
Finished off a few other little knick knacks and pipework but still need to do injector pipework (once casing fitted); tomorrows task will be the slide bars and crosshead area to virtually complete the chassis.
Couple of modifications to the chassis, there is a small risk of the Delta truck wheels shorting on the frames if you're pushing close to 6' radius and certainly below.
The Delta truck swing is limited by the ash pans hanging down in front and the weight bearing stay at the rear, so you need extra play in the axle, just leave the side control washers out. But that does run the risk of shorts so I cut two arcs in the frames to clear.
The second is cosmetic, the kit does not supply a floor for the sloped rear section of the ash pan each side of the frames and leaves an ugly gap. Simply fill in with new plate work angled to suit, a nice little light blocker and adds a bit more mass to that area.
I also change the way the cab floor (the bit with the backhead on) is fitted, originally designed it fixes to the chassis on those two raised plates at the back; it makes fitting the body/cab assembly over that a tad awkward when the backhead is secured.
I fit the cab floor to the casing (later in the build) but it has two straps on the underside to hold the pipework for the injectors etc. You need to add two dummy plates from the rear alongside the up stands (they're also another nice light blocker under the cab) and then add the pipework straps to those (later in the build).
The extra plate work should be easy enough to see/work out from the photos.
