Pickups.
For what it’s worth, I’ve tried split axles (following Steph’s method with fibreglass rod inside Slaters axles) using Slaters nylon hornblocks, a tender with split chassis & split axles, backscratchers, Slaters plungers, and my iteration of DLOS’ plunger design.
The latter is very satisfactory & easy to make but not easy to hide. Split axles are brilliant but a whole lot of work (though rather less if using cast metal wheels) Backscratchers are IMO a waste of time, effort, solder etc., on locos but are an option on tenders. I’ve not built a loco with US-style pickups, but have an aversion to live buffer beams. I’m quite keen on tender pickup generally, as it’s usually easy to hide stuff.
I came across these when designing a bed-of-nails tester at work. They’re plungers, but they’re tiny. I have no idea whether they will wear grooves in wheels or wear out in ten minutes, but these are small...
https://docs.rs-online.com/b80d/0900766b815846ae.pdf
and these are smaller still
https://docs.rs-online.com/ecf0/0900766b815836d0.pdf
There are also sockets into which these fit.
hope this of interest
Atb
Atb
