My modelling has taken a rear seat for a few days, but even so, both bogies, apart from the split axles are complete. I have now made the first cut in each axle and filled with Devcon 2Ton epoxy, and left to fully harden before making the final cuts from the centre to the outer edges.
I was amazed at how quickly the bogies went together compared with the hymek and DJH 47. I had intended to show a blow by blow account, but there wasn't really much to show! All the pipework is represented by lost wax castings and fits perfectly, so no fiddling and faffing with wire bending and worse for me...measuring!
The ABC motor bogie is very nice, and the locating holes for the bogies and springs all line up perfectly.
As mentioned previously, the design of the bogie makes it very difficult to utilise the cast in stud on the loco chassis, due to the very close proximity of the cardan shaft. Also, the end detail from the resin bogie needs to be grafted on.
The photos below should explain all these points.
Laurie has kindly sent me a frame with only one stud cast in so I will see if I can make this work.
Going back to my Hymek, the transfers have arrived so I may get those on later today. I still need to get a couple of Beyer Peacock makers plates.
