You really don't want to know what's been going on with this build, but I'll confess anyway.
I had the loco running on the rolling road when John came over to see it. All seemed well and good, but after a short while the thing would slow and stutter and eventually appear to grind itself to a halt. I was not pleased, but investigation revealed the problem to be the rear axle boxes were sloppy.
Nothing for it but to take off the rear wheels, extract the spring castings and axleboxes, replace the latter with a new set, replace the springs, wheels and so on. It went well enough, save I managed to accidentally heat up one of the plunger pickup bodies which caused it to stop plunging, so that had to be replaced as well.
I don't need to tell you all this, but it is cathartic. While I am an experienced modeller, I am still learning some of this stuff - the hard way. It was almost enough to make me decide not to accept loco commissions any more - too many moving parts! Coaches are much less hassle!
Anyway, things are running about as well as could be expected now. Thank goodness!
The driver is on the short side, so I've had to give him an old apple crate for his feet to rest on. If I feel up to it I will sketch in some marks on the gauges.
Meanwhile, buffers and couplings have been installed. The front coupling hangs low enough to catch things in the four foot, so I've contrived to hook the bottom link up on the tommy bar. Some paint retouching and a coat of satin varnish will complete details at both ends. I don't think there's anything left in the Box Of Bits To Be Fitted, so I will get the transfers sorted this week, then get both this and the Lanky Tank into the paint shop for a coat of protective varnish.
I don't plan to weather the Dubdee quickly. I think it'll sit on the test track while I mull how to commence making it filthy.
