Graham asked me off list if I'd show the case.
It's made by Parkwood Arts Ltd. You can find them at the various 7mm and larger shows. This is the largest loco carry box, and retails at £49.50.
Now, that sounds a lot, but when you expect to carry something that could be worth a hundred times as much, it sort of adds some perspective.
The top is held shut by three clips. On the shorter models there are two clips.
The rear has two solid hinges, which allow the top to lifted clean away when opened. This eliminates the danger of the box tipping as the model is lifted out.
The construction is solid wood, with well crafted joints on the corners. This box carry case is not going to fall apart, and will withstand most knocks and bashes.
The floor - also solid wood - is slotted for the flanged wheels to sit neatly.
Dense foam blocks are included, which are a snug fit into the ends. A length of lighter foam material is also provided, which you can trim to lengths as packing as required. I've cut it down to provide packing and cushioning along both sides of the WD. The case is a mite too long for the loco, so additional packing needs to be inserted at one or both ends. I discovered this after a trip in the back of my car where the box was not restrained, and it allowed the loco to shunt about inside as I was driving, resulting in the broken front vac pipe bracket.
As I said, the top is designed to come away from the base. I am just a satisfied customer, with no connection with Parkwood Arts otherwise. I think the quality of the construction shows through, and I shall certainly offer these cases to clients as "value added" to safely transport their new toys.
http://www.parkwood-arts.co.uk
