Do folk generally consider that an etch primer will key to all manner of model metal better?
Isn't it true that the thinner the coat the better as it will not cover up fine detail so much?
In which case (ignoring the advice on different base colour) and especially for something like a lacklustre WD, why is it not normal practice to just prime with a black and then give it another coat as the top coat? Especially if most of it will be covered with grime and weathering powders.
To answer your questions.
Yes I do think that etch primer will key to most modelling materials better, normal primer is only a paint with a larger size pigment in it? Saying that the better the surface is prepared the better any paint will stick.
Lets start with a sheet of brass, it's come to you with grease finger prints Etc. on it you could paint it and the paint will stick to it, but for how long and how well???
Remove the grease Etc. and the paint will stick better.
Polish the sheet and remove all the grease and your not far off back to stage one (locos look nice in shiny brass, but)
Remove the grease then grit blast the sheet, the paint will stick better but you could still have dust from the grit-blasting on it, so it should be cleaned again to remove the dust.
So for the best clean I would say, remove the "muck" grit-blast and then ultrasonic clean the part and dry off and apply the primer when the part is still warm.
Normal primer will work in all of the above but I think that etch primer will work better.
I may have to do a test on a bit of brass to find out?
OzzyO.
