Probably worth an update on what stock I have got / will be getting and what its status is.
Passenger turns:
- Adams O2 - nearly completed Connoisseur kit 30200
- GWR 8750 - RTR from Minerva to become 4666 (DCC sound fitted)
- GWR 45xx - RTR on order from Tower models to become 4569 (DCC sound fitted)
- Ivatt Tank - Built from an ACE(?) kit by Peter in Brazil as 41275
- Drummond T9 - Kit on order from Finney7 to become 30719
- Bulleid Light Pacific - Kit bought from Finney7 and not yet started, not decided which it will be 34033 or 34066 are potential numbers
- AEC RailBus - Heljan RTR, I've fitted DCC sound.
That's the locos, most of which were classes all seen at Bodmin North. The 45xx fits in with my perverted version of history cooked up for Pencarrow. The T9 and the Bulleid are both classes local to the NCR but are a big push to justify at Pencarrow but are two of my favourite classes. The stock has been acquired to cover a 20yr period of operation, starting with the O2 and ending with the Railbus.
For coaching stock we have:
- Maunsell P Set - part finished built from Slaters kits and will be finished in BR(S) green
- GWR B Set - RTR from Dapol/Lionheart finished in crimson
- Bulleid loose BCK - not yet sourced, ideas welcomed
I'm also thinking about eventually getting an earlier set of LSWR coaches, a 7mm version of the recent Hornby jobbies. Again suggestions welcome.
Freight turns
Much less variety here but two main turns, mainline and the clay branch.
- Maunsell N Class - kit ordered from David Andrews last week. Likely to be one of 31843/4/5.
- NB 63xx / Class 22 - interest expressed in the LLC project. JLTRT obviously now not an option.
That's it for the mainline, although the 45xx and 8750 could also be used for GWR trips?
For the clay branch we have:
- Beattie Well Tank - not yet started but this will be a montage creation from bits and etchings sourced from Laurie Griffin and Nick Easton and finished as 30577. Easton-Griffin 0298 Beattie Well Tank for Pencarrow - 7mm+ modelling
- GWR 1366 - mostly complete, started as a Agenoria hit but now has many replacement and scratchbuilt parts, including a completly new chassis. Will be 1369 at some stage...
The only addition I can think of here is an 03 to take on clay duties in the diesel period. Again suggestions welcomed.
The freight stock will be about 90% kit built from plastic and brass kits. Good headway was being made into the pile of kits but I've stopped to concentrate on getting a running layout.
Whilst I now have just about everything in my original targeted stock list from 3yrs ago, there are still a few gaps. What I have learned is that you really do have to get things when you see them or risk not getting one later. Manufacturers going bump it retiring, moulds no longer useable and short production runs all cause issues.
