Ken
- that brass is probably thicker than the cortina
I've found few pictures of the top of the firebox, but from what I can see there is a single row of rivets. If you can point me in the direction of reference pictures, that would great.Mike, on the standard 9f there's a double row of bolts/rivets down the centre line of the box
same as the side.
Ken
I'll try to remember to add them later.sorry Mike my mistake they over lapped the top and fitted a single row
Ken
That makes more sense to me.Hello Mike,
reading Mickoo's post says that the twin pull rods are under the ash pan and single rods run to the front.
I can understand the logic of this the ashpan is opened and the ash just drops into the ash pit with nothing in the way.
ATB
OzzyO.
Thanks Dave.Mike,
Not quite. 9Fs had two (steam) brake cylinders operating two separate systems. On your diagram, the single pull rod between the 2nd and 3rd axle doesn't connect the two cross beams but is shorter and connects to the front brake cylinder via a bell crank, as shown on my rather scrappy sketch, which also includes part of a drawing from the Dave Bradwell chassis kit instructions which shows the support bracket for the front crank (part 14).
Hope this helps.
Dave.
Hmm. Not sure. We'll possibly never know. I'll probably go with the conventional 9f set-up. It's not hugely visible anyway. But thanks for your thoughts on the subject.Hello all,
would the Crostis have enough room to fit the front steam brake cylinder in place when they had the preheat boiler in place? If not would B.R. have gone to the trouble of fitting one when the preheat boiler was removed, I think not.
Just something to think about,
OzzyO.
