spikey faz
I forgot to take pictures first time round. Too busy burning my fingers with solder!Pray tell us how you did that.
OzzyO.
I'll get some pictures in due course.
OzzyO.
It is. Thanks.
Extremely helpful. Thanks.Are these photos of any use? Not my copyright so please don't repost, I'm only posting them for information.
That did cross my mind, but to be honest I was getting a bit weary of such things. I may still do this if it all falls apart further down the line.I'm a bit surprised that you did not drill and pin one of the fixtures.
ATB
OzzyO.
Yep. As far as I can ascertain it's 3 x sandboxes on each side.Don't go to mad on the sand boxes as looking at photos of Re built Crosti 9Fs only had sanding to the front driver and to both sides of the driven wheel (flangeless wheel).
HTH
OzzyO.
The kit kinda caters for this in that it presents a flat outer face, but it's a bit 2 dimensional. I'll have to beef it up a bit.Just found some more photos that confirm the high, forward position of the rear RHS box was retained. Unlike the other three boxes, which were close to the frames and had the sloping face to the outside, the odd one was immediately inside, touching even, the running plate and appears to have been mounted with the flat face to the outside.
Dave.
I've been going through many pictures of Crostis in an effort to work out the positioning of the sand boxes. I think I've sussed it and will post my version of events in due course. By making the sand boxes removable I'll at least be able to reposition them if I'm wrong.Hello Mike, been looking at sand boxes. the front fillers are on the front face of the apron beside the outer steps at the top,
they feed the front wheels only. the other 2, one is just behind the reverser g/box and the other one is in front of the shaft support
bracket, the pipes are one in front and one behind the centre wheel, it looks like the boxes are fitted to the chassis between 2n3 and 3n4, front one is not visible. I would send you pictures if i knew how.
Ken
