Well, I've ordered some brake parts from Ragstone. I'll use these to cobble something together. Hopefully it'll look OK.Did the cross beams not have equalisers?
Gonna stick with the ones I've got. Spending on this project is getting a bit high and I need to rein in my spending. Got funds put aside for next project (which incidentally is from MOK) and my hifi amplifier (Quad) has just conked out, so need to get that sorted. Oh, and Xmas is coming!mok shoes 3.70 + p&p
Thanks KenMike, if you haven't done the brake linkage yet, go on mok website and put in updates, then 9f
#chassis no 8 there is a copy ofthe brake diagram.
Ken
Ah! That makes sense. I'm tempted to make the windows up as a separate assembly complete with glazing and fit them after final painting.IIRC the small window goes to the front. The second etch (the one with the open end) could be used with the "open" end to the front to represent a closed rear window. Or used with the "open" end to the rear to represent a fully open window, or by cutting bits off the "open" end any stage in between.
ATB
OzzyO.
Great pictures! Thanks.We've (WT) been here before with 9F windows, last year? Maybe the year before?
There are two sliding windows on the 9F, both the same size and both capable of being at the front or the back.
Generally...not a hard and fast rule....the outer one is usually at the front and the inner one toward the rear, but, there is plenty of evidence in the real world of them being the other way around, photos of which I put up last time.
If you want to avoid finger pointing and go with modeling convention then place the full etch with the different sized openings onto the cab side first and make the smaller opening at the front, then add the over lay with the full opening to the rear on top of that with the fingers facing forward.
If you want to wind up the anoraks then flip them around, it sends them loopy with wailing and arm waving you've got your windows the wrong way around...which is complete bunkum
Beware though, not all engines have double sliding windows, a great many have fixed front ones which will always be outside of the sliding one![]()
