S
SteveO
Guest
Cheers Steph
Since I got a pretty sensible answer to the last complete-noob question, I'll ask another.... Markits vs Romford (and.... others out there?) in the choice of gears; is it simply a personal choice thing - or are there significant/important differences that might influence ones' choice? Or is the "difference" more with regard to the physical gearbox dimensions and simulating size/shape/proportions of popular alternatives?
Happy to helpCheers Steph
Cheers Steph. Incidentally, how many Romford 40:1 kits did you get etched? Also, do you know who the Mashima wholesaler is? I can't this information anywhere.
Steph, the gear boxes look very useful. Much better than the alternatives and I won't need to solder on various bits of etch waste and wire to make them rigid as I have done to other etched gear mounts. One suggestion, could you add a dimension or two to the planning drawings so we can check that we have printed them to scale?
I was going to ask the very same, Steph could you please explain the differences (and bear in mind that my next 7mm loco kit will also be my first …)
Does my answer above help?
No helical drives, (yet)?
Any tentative plans for a final drive gearbox with bevel gears? I had a hunt around for them before and couldn't find any small enough for even 7mm locos. Might be a nice option for hydraulics and DMUs and allow back driving.
