More ....
I don't have the Wild Swan books - yet. They are waiting for me at my brother's house in Manchester for when I visit England in August!
So thank you for the dimensions, above. As it happens I do have an official engineering drawing obtained from the NRM, though.
The footplate is exactly the correct external dimension, but the footplate width on each side is 16.7-16.8 mm. Taking this back to 15mm will remove the line of rivets, as Adrian says above. I am optimistic that my skills are up to re-creating these, however. Probably line them up before I file back the inside of the footplate edges. The NS sheet, even over the etched areas, is still 0.5mm thick.
This will affect the small slots used to locate some other parts. I don't know as yet what parts are affected, but I will just have to find that out as I go along, I fear.
Incidentally, if anyone wants the "pipes drawing", as my drawing is called, I also have a high-resolution <.tiff> file of it which I could share on request. The orginal is about 2m across!
David
