TFW’s workshop
Rather stormy of late.
Inspired by our rather busy and spectacular weather systems of late, I have extended the storm on CF.
It also serves to ‘lose’ the hole in the sky.
The layout has now been put into hibernation until September, so here is an exciting picture of the storage boxes.
With all the work that has been undertaken of late I would expect we will have trimmed off 10-15 min for set up and take down times: not at all trivial when exhibiting a layout of this size and complexity.
Back to the 9P
I have resumed work on Valour, the GC 9P / LNER B3 over the last couple of days. I have etches for the engine & self trimming tender reduced from 4mm scale, courtesy of Nick Easton & Paul Craig (if anyone is interested in a set - as a scratch building aid - please PM me). Even though the chassis could be used with extra bearings and spacers I preferred to make up a conventional phosphor bronze and double sided PCB structure. I know these work well on CF. The errant extra holes in the PB strip are a function of using some frame material from a previous project.
The two brass tubes and 14BA bolts that are used to set up the chassis are old faithfuls: they have been used on all my scratch built engines since 1982 and are removed once the chassis is soldered up. The alignment of the frames is simply checked by using drills as sighting rods and then the double sided PCB soldered into place.
The kit frames are in 8 thou nickel silver and are used as an overlay and will also support the cylinders etc, supplied in the kit. However, I wanted to have the front end removable so that the cylinders & motion support brackets can be made away from the rest of the engine.
The front assembly locks into place and is held precisely by two 16BA & one 14BA bolt. The kit is supplied with the spring etches and so it would have been churlish not to fit them - they can be seen quite well through the large wheels.
The rear cosmetic frames are fixed to the main sub assembly with 16BA bolts and the axle holes opened up to 1.6mm, so as not to impinge on the 2mm Association brass stub axles. The wheels are only placed loosely in the chassis, at the moment. I will set the chassis up with some trial muffs shortly and, of course, make the coupling rods. The worm gear head will be a massive lump of brass that will also occupy the ash pan.
Quite quick progress, for me, but it does help having the etches. Valour should look very fine in full GC livery on CF.
After a few days in Lynton in the camper van, with zero internet and phone coverage, I have made the side rods for Valour using the kit etchings. Nick Eason has designed these for a sprung / compensated chassis in 4mm scale, so they have a correctly articulated joint. This feature is not needed in 2mm FS, so I very carefully made the joint solid, taking care to maintain the inter - pin dimensions. This paid off, because as soon as I had assembled the chassis with temporary testing muffs the rods worked with zero binding! This is a first for me, but the chassis had been drilled on a new watch-making co-ordinate drilling machine I am very lucky to have.
Not the most exciting picture.
P A D
Hi Tim,
It would be good to see some photos with a ruler in shot, or on a lined cutting mat, so as to get some idea of the size of the model.
Cheers,
Valour’s worm gear housing has been fashioned from a lump of brass using my John Stevens watchmaking mill / drill. It can be seen with the milling head in this picture, with a tooth brush for scale.
The head was then changed for the drilling attachment to drill the 1.5 mm hole for the worm shaft. There is zero backlash in the x-y table, although obviously one doesn’t rely on this when using it. I find Roco RTD excellent drilling and tapping lubricant.
The milling head can be tilted at all sorts of jaunty angles, as can be seen for making a clearance slot for the worm wheel.
The brass block was filed to be a tight fit between the frames and then drilled through the frames for the fixing bolts at tapping size, with the worm positioned on the worm wheel at the correct meshing centre (the worm is over-long). The frame holes were then opened up to clearance size.
This photo includes part of my thumb for scale, with wheels just in place and not anywhere near the correct gauge: they will be hard up against the frames when completed. The block was then milled back by 0.5 mm to avoid shorting out on the other side of the split frames. Finally the sharp corners were removed, as good engineers don’t like sharp edges.
The last photo shows the two 16 BA bolts nestled into the frames. The worm will be shortened and have a thrust washer between it and the bearing block. The universal joint from the tender motor drive will be at the right hand end.
P A D
Very nice Tim.
Either you have hands like shovels and big thumbs to match, or that is one tiny chassis!
Cheers,
Quite a good view of Valour’s worm / worm wheel set up with one wheel removed.
The worm has had been trimmed to length and thrust washers fitted. Whilst the 38:1 worm wheel is visible in a broadside view like this, it will not be such an issue when the engine is complete - and will certainly not show on CF!
The chassis was re-assembled with wheels set to Irish broad gauge: final gauging will follow chemical blacking of the frames and wheels. It turned over by hand OK:
It was then put under power.
Good enough for government work.
D6356
great work , must be government work covered by DORA or MI2.00 as last to pictures / videos have been "deleted" to protect the innocent, well I cannot see them anyway!
Robert
Fiddly bits...
The reason for making Valour’s front end removable was to enable the front end to be made independent from the main chassis as it is quite complicated, with an awkward motion support bracket. As the etch has been made in 8 thou nickel silver, the slots or tabs need adjustment; I find a fine slotting file ideal for opening out any slots. Careful cleaning up of the etch cusp is also important to ensure a good fit of components, when dealing with a kit that has been reduced from four to two mm scale.
The slide bars consist of two components that make up a Tee section.
The motion support bracket folds up into the required shape very well and it simply requires the slidebars soldering in place.
Four hours later...
When people look at models they often say, “You must have a lot of patience”. I think it’s actually more a case of perseverance.
The outside cylinders are angled and so need to be lined up carefully with the centre driving wheel. This was achieved with sighting rods which were also used to align the motion support bracket with the cylinders.
The L&R brackets are held in place with the two 16 BA bolts at the front with some PCB on top to stabilise them. These brackets could be permanently soldered to the front frames when the detailing and mechanical bits are complete, if the PCB is too visible under the boiler.
The next job will be to machine the rear cylinder covers and stuffing boxes, the piston guides to fit in the motion support brackets, followed by the crossheads and piston rods.
The final picture is for scale:
P A D
Tim,
You must have been a watchmaker in a previous life, or you really do have big hands and the model is 7mm scale. :D
4 hours and "very little" to show for it. It's the same in all scales, but what amazes me is the number of tools that can be piled on the bench after assembling a relatively small component.
Cheers,
I really didn’t like the lump of PCB on the motion support bracket: it would have been too visible. It was therefore replaced with another piece of copper clad, slipped in under the nickel silver cross pieces towards the front, where visibility is restricted by the frames. At the same time, I made two dummy bits of valve gear for the inside cylinders which serve to strengthen the joint and show some ‘business’ in the area.
The rear cylinder covers, piston rod guides and a temporary front cylinder alignment jig were turned up and fitted. The rear stuffing boxes will need filing to a lozenge shape for the top and bottom studs.
The alignment of all the assemblies has stayed true, as can be seen by the piece of pivot steel acting as an indicator. The pistons will be made of this very useful material. .
Crossheads will probably be made next.
Crossheads are always quite fun to make. Silver soldering is a good way of ensuring that at least the piston and inner crocodile are nice and solid. The starting point is a piece of thick metal (0.7mm thick) to fit between the slide bars with a notch at one end to accommodate the 0.5 mm diameter piston. This also benefits from having some flats filed on to it to give a more precise location.
The silver solder was in a paste form and very easy to flash the joint with a little gas flame.
This was then placed in the vice and the socket for the piston filed into the end, rounding off the corners, taking advantage of the safe sided file.
Alignment in the slide bars was then checked: at this point it should be a tight fit.
Followed by a 1mm diameter hole to accommodate the little end of the connecting rod.
This was then opened out rearwards to be able take connecting rod. The outer face of the cross head can also be seen resting against the slide bars.
Making two of anything can be easily achieved by sweating two pieces of metal together and roughing out the shape, just once, then separating them. The little end pivot hole is 0.3mm diameter.
The two components were soldered together using a tapered stainless steel pin to stabilise the outer face by holding it on a charcoal block whilst the inner face was held onto it with downward pressure on the piston. This assembly was joined with electrical, relatively high melting point soft solder, as I didn’t fancy my chances at the whole lot not melting down into a blob if I tried to hard solder it. I normally use steel for valve gear - which would be less likely to melt, but as this is kit is etched nickel silver, that is what I have used here.
A tight but smooth fit is what was aimed for at this stage. Subsequently, the mating surface of the cross head slippers was filed using a slotting file to give a running clearance with the groove locating the cross head on the slide bars.
The outer cross head face was filed to represent the prototype and the piston socket dressed to look more convincing. The little end of the connecting rod will have a pin silver soldered to it and the round outer boss of the cross head will be represented by a washer soldered onto this pin to hold it in place.
It never ceases to amaze me what you can do with a phone camera.
Hi Tim,
That looks satisfyingly complex - even at twice life size on my phone screen - and elegant in that slightly chunky way that GCR locos often seemed to be.
