Another little workshop guide for information - making lamp-irons.
It's another one of those little details which I like get right. For me I'm not keen the etched solutions, particularly when there is a step on the lamp-iron. They are ok for the plain bent ones but as soon as you start to fold them back on themselves they are getting too bulky. In the same way lost-wax lamp-irons are too chunky and need a lot of filing to thin them down.
So this is my method for making lamp-irons. First I get a strip of nickel-silver, usually just a scrap part from a etch usually about 5 to 6mm wide. At each end put in a 90 bend so that the main part sits vertical on the base sheet.
These strips are then silver-soldered on to the base plate. I cut the solder in to little pellets (pallions) and place on the joint and then coat with some easy-flo flux mixed up in to a paste.
This is very gently warmed with a torch, first the flux goes translucent, then starts to boil the water off
As the water boils off you are left with a white residue, increase the heat and then it starts to melt. Then as you bring the metal up to a nice red heat the solder suddenly flashes across the joint. It is quite noticeable.
A short dip in the acid bath to remove the worst of the flux residue.
Back to the workbench I then cut a slice.
A little filing and bending later gives me the following lamp irons. The first couple were rather variable but there is plenty of material so after a few attempts I managed to get 3 that looked vaguely similar.
The beauty of this method is that I can soft solder them to the loco without any fear of them falling apart.
