John57sharp
Look in the part now. 2nd side went together better with experience?
Yes, definitely easier on the second side.Look in the part now. 2nd side went together better with experience?
I love resistance soldering, and with a sharp electrode, it is possible to put just enough heat into a job to make a joint, without melting everything else
To be fair the MRJ parts are fine. Any errors are purely down to me. At least I won't have a box of left over bits though (I hope!).Been there, done that, trying to build a kit for a 1366 pannier.
I think the box of bits left over was over 50% of the weight of the kit...
Atb
Try and get some pewter foil. It's usually a military modelling thing, but I imagine eBay or Amazon could oblige. Very pliable and can be used to represent folded fabric. Probably great for wagon sheets too, although I've never tried...
It seems very strange to see ‘Jane’ resplendent in maroon. I liveried my own version of No.5 in BR coach maroon in 2006 much to the horror and dismay of fellow modelers and Wantage Tramway officianados... I’m gratified that the museum saw fit to follow my leadWhat no Crimson King.....![]()
Hi Mike, I’m pleased my version of No.5 giving you more impetus to keep with the project. My version was finescale, so I didn’t have the challenges you will be having to deal with in S7. If I recall, getting the valve rods to work without binding took some time to fettle and ensure reliable running. My loco is Escap RG4 powered, and while very smooth in operation, doesn’t have a great deal of torque, so any valve gear issues were cruelly exposed. The video shows the slow running capabilities quite well. I do have other images in higher resolution, happy to share if you think they may help. I can recommend fitting DCC - the Loksound V3 chip fits inside the well tank perfectly!Hi Ian
I think I found one of two of the pictures you took while doing a Google search for info on No.5. This is however the first I've seen them with the others and also the video. Fantastic! Really inspirational for me. I've got to see this project through to the end.
I've got a few bottles of wine to experiment on with lead foil.
I'm still not sure about colour, but erring towards green at the moment. I'm only building the loco, not the Wantage Tramway. No.5 has simply been sold to the Findon Limeworks and I guess they fancied a change of colour.
