steve50
Thank you, I did try that on a wagon or two but the factory finish was so smooth it was difficult to get the paint to stay on and when it did wiped off after I'd thought it dried.Hi Steve,
Re the fading I use greys/white in oils and work that over the body surfaces; you can do the same on coaches and wagons. It’s all about how much you leave on the surfaces that creates the level of fade.
I'll try a light coat of Matt varnish as a key next time.
This is something I’ve shared here before, but probably the simplest method of replicating faded paintwork is to spray the surface with thinned white paint, acrylic being the best as you can dry each coat with a hairdryer as you go to speed up the process.
Pelle Soeburg, a European modeller modelling in American HO, is an exponent of the art and uses it to attain the chosen weathered result in the shortest space of time, hence the title of one of his books on the subject: Done in a Day.
Here’s a photo from the cover of his book that shows a representation of a BNSF, formerly red in the main, diesel that’s been exposed to the harsh Californian sunshine, to give you an idea:
I recall he fades the uppermost surfaces more than the others to achieve the most realistic effect before progressing to other techniques.
Of course, it’s not as detailed as Neil’s work, however, it’s aimed at the modeller short on time or skill and I think is worth a go just to familiarise yourself with the technique and to judge whether it’s for you, as I mentioned, in a very short space of time.
Thank you, I have actually got that book somewhere on my shelves! I will certainly dig it out!
Steve.
