Haha. I watch as little tele as possible. Architecture and structures have interested me since art school days.LArry, I know you've retired from a successful career, but are you a frustrated architect?
Do you spend your non-modelling time watching "Grand Designs"?
Hi @LarryGvarnished with Halfords Satin Lacquer
I think we've discussed totem sizes before.While awaiting a signalbox kit, I decided to spruce up a second-hand Small Prairie by rubbing off the original insignia, spraying it lightly with Halfords Satin Black and affixing large pre-1956 totems, varnished with Halfords Satin Lacquer.
The totem are 9mm high off Methfix sheet B3, replaced in later years by BR Sheet 14. Transfers on the latter sheet were slightly larger with the large BR totem coming out at 10mm high.
I intend making up a new smokebox number plate. 4560 worked on the Cambrian section in BR days...
Mike (@Quintus)If I may comment , not wishing to pre empt Larry's reply, I had a very bad experience spraying varnish from an aerosol onto a recently completed 7mm coach side, which lifted the paint, resulting in a terrible mess. I had sprayed prescision paint with my airbrush, and thought acrylic varnish would be OK. I came to the conclusion that it was the propellant in the aerosol that caused the problem rather than the varnish itself.
regards
regards
I can imagine the anguish. I've used cellulose since the early 1960's, mainly for speed. Anyone remember the 'Celspray' spraygun? It was like a scent bottle with a hand activated bulb. I once sprayed 50 Hornby TT gauge coaches for George Mellor (GEM) using the darn thing. You should have seen the sags across my hand. By 1970 I was using a DeVilbis Type M miniature spraygun while dad built me a compressor.If I may comment , not wishing to pre empt Larry's reply, I had a very bad experience spraying varnish from an aerosol onto a recently completed 7mm coach side, which lifted the paint, resulting in a terrible mess. I had sprayed prescision paint with my airbrush, and thought acrylic varnish would be OK. I came to the conclusion that it was the propellant in the aerosol that caused the problem rather than the varnish itself.
