john lewsey
That looks really good Heather
Let choirs sing and trumpets play! I've started work on the RMB again today!
The leedle grey cells 'ave been worrying away, and I set about fabricating the self-adjusting brake doodahs.
From my notes, I have an outer brass tube 2.5mm OD/1.5mm ID, 15mm long. Inside that a brass tube sleeve, 1.5mm OD/0.6mm ID, 20mm long. Through the whole thing is 0.6mm brass wire, with a pivot bracket formed at one end by hammering flat and drilling through.
Good enough, I think.
There can't be many people around who open an MMP kit, look at the etches and castings and think to themselves
"Well this looks ok, but it will require some detailing …"![]()
Graham and I had considered spot soldering to a piece of scrap. These are further complicated by needing to have the holes drilled at either end and a fixed distance in between.
I will try spot soldering and feedback.
Try using a pin vice, it works for me.
This was covered in, I think, the Mk.1 Resources topic where I produced a couple of photos - I recollect that Bob Reid advised that the purpose of the bracket, rod and adjusting screws is to ensure correct alignment of the dynamo.A query: there's a bracket and threaded rod fixed to the longitudinal frame, which seems to have some bearing on the dynamo bracket. I can't work out its function...
Bits and bobs? Nice choice of words, given what VERY nearly happened to me once, lineside in France as a train rolled by.........
A couple of battery boxes. Lots of parts, fragile overlays, and some RSU work. A little untidy, but I think it'll look fine painted and grubby.
Very nice, it's a shame that David isn't able to offer those separately from his kits.
Rob -
We used to + body fittings/gangways - but hardly anyone bought them!
