They are indeed. Brass strip from Holiday Holidays.Please Mike, are the new buffer beams from solid brass? I might re-do the wooden ones on my 'Nellie' crane tank one day.
Hi RichardPlease Mike, what is the lump in the chassis near the buffer beam? I am guessing a part of the Dapol chassis block which you are retaining to look like a counterweight for the crane?
I've not much info to go on, other than the above plan. Any advice/ suggestions are very welcome.Curious looking beast.
Interesting (and logical) that the slew bearings are so widely spaced.
I wonder how the bunker was designed to take the side-loads down into the frames.
I would have thought that the bearings were mounted in a 'box' of which we are seeing the side frame? That would perhaps sit tight between the frames, which must be beefed up somewhat not to be twisted as the crane slewed with a load. There must be inner frames behind the trailing wheels anyway, but even so......Curious looking beast.
