You need to shorten the bracket holding the reversing lever cross (weight) shaft so that the shaft is centred in the frame hole, then you need to redrill the expansion link pivot hole in the radius rod closer to the slot.
That will also move the valve slide block into the middle of the slides, where it is now runs the risk of the crosshead smacking into the combination lever at full forward stroke.
It also looks like the combination lever is much too long, the slope on the union link is excessive.
