Still beavering away making slow but steady progress. Next up were the front bogie top bearers (or that's how they are referred to in the instructions) and the fitting of the bogie itself. The former were easy, tin with 100 degree solder and use the RSU to heat from inside the frames.
The bogie fitting was a little more challenging. My fitting of the representation of inside motion had scuppered using the method that the kit provided. At Guildex I had a chat with Nick about how he had done his and he confirmed what I had thought would have to be the solution. Which is do it like the prototype (simplified of course) and fit a plate to the bottom of the frames. This proved challenging because of my seeming inability to drill a hole in the middle of a rectangular plate... It took three attempts before I got the hole in the ruddy middle. Actually, I am being a bit hard on myself. The first one was in the middle it’s just the plate was too small…
With the part finally ready to be fitted I turned my attention to the mounting screw and the 'nut'. The kit comes with a nice turned elongated top had type bush which is threaded 6ba in place of a conventional nut.
I had already made the side control springing block to accept this threaded bush so I wanted to use it. However now that the fixing point was much lower in the frames.
What I couldn’t work out was whether the bus was threaded all the way to the bottom of the hole or not because I didn’t have a long enough 6BA screw to check. So rather than trying to shorten the existing bush I thought it easier to turn up a new shorter version. I also turned the first 0.45mm to just fit tin the hole in the mounting plate which is slightly larger than the screw.
Despite my messing about for quite some time with a stack of washers trying to work out how long the shortened bush needed to be, it ended up slightly short.
Thankfully I had the foresight to leave it attached to the rest of the stock so once I worked out how much longer it needed to be, it was and easy job to turn another 2.5mm down to the same diameter. A short length of spring allows the bogie to float up and down by about 1mm.
Having got this far there doesn’t seem to be much in the way of swing before it hits the inside of the cylinders but this may change when on track and the side control does its job. Time will tell whether I need to cut back the cylinder wrappers.
