Peter Insole
On this fascinating subject there is quite a bit more that I could go rambling on about, but this morning I remembered that the purpose of this thread is more to do with the model build! I shall now therefore move hopefully closer to the point...
At the top of my priority list of previously unobtainable details was the steam brake valve - with particular emphasis on determining not only the precise design of the original fittings, but most importantly, what material each part was made of!
Here is the unfortunate "lash-up" job on "Wren" at the NRM:
![hpbhmSAM_3084.JPG hpbhmSAM_3084.JPG](https://www.westernthunder.co.uk/data/attachments/220/220194-512144f33df6ccab282b9facad651bef.jpg)
This, along with several other reference shots, at least provide sufficient information to make up the main body, complete with slightly tricky to make backstops on wings! The thick brass lever handle is evidently an almost useless bodge of the lowest order though!
Below is another cropped image (usual copyright disclaimer) and previously the best I could find to show more of what it should be like - on a Horwich built loco anyway:
![horwichwren 8b Midget c1932 LYR-class-Z-0-4-0ST-Photo-Lancashire.jpg horwichwren 8b Midget c1932 LYR-class-Z-0-4-0ST-Photo-Lancashire.jpg](https://www.westernthunder.co.uk/data/attachments/220/220195-e766020b870eedabc286bf35651bdae9.jpg)
Finally, two pictures of the genuine article, or at least one that matches what can be discerned in available drawings, and appears more likely to have been originally supplied by Beyer Peacock...
![hpSAM_yy0053.JPG hpSAM_yy0053.JPG](https://www.westernthunder.co.uk/data/attachments/220/220198-1ecb9c846d742ee7fa64fb4254859590.jpg)
![hpSAM_yy0113.JPG hpSAM_yy0113.JPG](https://www.westernthunder.co.uk/data/attachments/220/220196-e5abcd4cf733bea431ec23ebd7e0e358.jpg)
The first thing to say about these last two images; please ignore the peculiar steam valve, handwheel and additional pipe fitted to the top of the manifold... these items are later additions; providing a separate supply for a small "Beccles" type pump, fitted to augment the single injector, and unique to BP's own "Dot"!
The other is that the steam brake valve body on this engine is very slightly different from both the specification, and the Horwich ones - with the backstops set further inboard - and ironically, (considering that I want a Horwich variant) marginally easier to model! Every other part matches the drawings, although clearly, some of the later examples (including "Mouse") had shorter and thicker handles on the levers!
I had hoped that in finally, and literally getting "hands on", I would be able to discover whether the lever and/or handles were manufactured in either steel or non-ferrous alloys... naturally assuming that it would be an easy matter to distinguish - and subsequently replicate on the model.
![hpSAM_yy0099.JPG hpSAM_yy0099.JPG](https://www.westernthunder.co.uk/data/attachments/220/220201-9b809477230ed0807ae81aabb32dd529.jpg)
![hpSAM_yy0100.JPG hpSAM_yy0100.JPG](https://www.westernthunder.co.uk/data/attachments/220/220202-0685e20895f5fdf2cdf761c05eb5a072.jpg)
Pah! Like hell it is!
One of the curators suggested that the distinctively dull, grey (with an almost Mazac like appearance) material might be gunmetal?
I have always been under the impression that as they are subjected to pressure, all steam fittings are usually made in bronze or gunmetal anyway, but that common brass is a perfectly reasonable substitute to represent both when modelling a polished finish?
The really big question now is; what colour on earth were these levers when still in regular service?
Did they look generally brassy, bronzy or steely - and if none of those, what can I possibly use to make it?!
Pete.
Pete.
