Hi David,
It was good to meet you to.
I'm building it as 60030 Golden Fleece as running in the second half of the 1950s.
I believe the Keighley MRC are having an open day on 30/12. If I'm going I'll bring the A4 along and if you can make if as well you can have a look in the flesh. I'll drop you a PM if I'm going.
Back to the build. Using a pair of spring bow dividers set to the spacing of the existing holes, I marked the position of the three new holes and drilled them out. The three superfluous holes were then filled and rubbed down. Here's the result. Thanks again to Bob Lumley for giving me the heads up.
I have also made an addition to the spring housing on the buffer beam, by adding a piece of waste fret to represent the packing at the rear of the spring.
Not a big difference but nearer to prototype. Looking at this reminds me that k need to make the fixing brackets for the bogie splashers
Before moving on to the valve gear, I want to get the connecting rod and cross head up and running. In preparation for that, I've converted the front and middle crank pins to 10 BA bolts. The rear one have been left with 12 BAs as they will have cranks for the lubricator abd speedo.
And with the coupling and connecting rods in place. I have also fettled the etched on "corks" on the bosses to make them look a little more realistic.
Cheers,
