More 3D Lego, in this case an EMD MP15 model from Atlas.
I've never been happy with the battleship plated window surrounds on RTR models, finding a solution to that will help me move forward with several projects. I've tried etch and whilst perfect for wall thickness is fiddly to fabricate and assemble, let alone delays in drawing it, modifying it and getting it posted along with associated costs.
Anyway, a quick dabble in CAD and it's better than I expected but not where I want to end up, the original MK I was a complete unit but took an age to print and no matter how it was oriented would have artifacts on the surfaces, the MK II seen here is the IKEA version with four flat packed walls, it works well and the outside corners are nice and crisp though there are a few gaps inside and I'm still trying to find a good adhesive to bond the parts. MK III has a roof section but it may not get used, either way, 3D roof or not, both will be covered in a brass sheet to give the sharp thin edge to the roof ends.
I do need to tweak a few details and look at other ways of getting better corner joints, that'll all come in MK IV and more if necessary.
Are the window surrounds thinner, well yes, a reduction from the RTR 1.8 mm to 3D 0.6 mm; in that aspect it's an improvement.
