richard carr
HI Mick
The SD35 cab is just brilliant, you don't happen to have a spare one do you for my SD35 ?
Might haveHI Mick
Front, nose and steps are already drawn, it'll need some tweaks to suit the new machines greater accuracy and work out the optimum orientation, then the sides, rear and roof can be added. But that's only when I have solved how to make it all fit as I'm aiming for the Airfix, Tamiya kit component approach, rather than a full blown complete module at the moment.A question I actually knew the answer to, and Mick beat me to it by several hours!!
Love the work on the cab, Mick. Don't forget to add CF7 Angle cab to your 'eventually' list....
Jonte - great work on that fuel tank!! I bet that is quite unique in modelling circles.
Not following the SP myself, I wouldn't have known.I've been happily banging on with the SP L screen and some guy over on the SP modelers FB page just quietly tipped me off that the SD35 never had the L screen, I knew this of course
My version would like to have the deeper ('dropped'?) Engineer's front windscreen, just to be awkward... (as on my HO version)(ReCF7) Front, nose and steps are already drawn, it'll need some tweaks
NotedNot following the SP myself, I wouldn't have known.
Simon, all forms of STL printer require the FEP to peel clear of the item with each layer, even the Form. If it doesn't then the fresh resin can not flood back in ready to be burned for the next layer.I spent most of the post up to the punch line trying to work out how you built a nose cowl on top of a road barrier.
Having only used a Form, I didn't know that the sheets of FEP came away until there was a decent amount of built resin to stop it moving. Presumably there is still a scarificial edge to get around the scalloping between the supports?
SD40-2Mick, do you have any of your excellent close-ups featuring the handrail stanchions?
My gripe is the dreadful stanchion shape chosen by MTH - what I call Priest's Hat cross-section. Starting with the GP9s the EMD cross-section has been square, flat U, but it's not that simple these days: varying widths, not just bolted to the side of the frame, but continuing below it(?) which gave MTH the excuse to have most of the stanchions punched together with this easier cross-section and joined by a continuous fold inwards.
Jason
I vaguely recall reading or noting somewhere in the past that the rolled versus clamped top on the stanchions were based on the joints between rod lengths, where clamping types were used at the ends of rods and rolled types were used at intermediate positions. I'd have to dig to find that reference though. It doesn't really matter much I suppose.Note there are two types, fixed with a rolled over top and removable with a bolted clamp....usually around the rad section.
Most excellent!I vaguely recall reading or noting somewhere in the past that the rolled versus clamped top on the stanchions were based on the joints between rod lengths, where clamping types were used at the ends of rods and rolled types were used at intermediate positions. I'd have to dig to find that reference though. It doesn't really matter much I suppose.
Anyway, here's some additional information on the stanchion. These are pdf's, so attached at the end. Note that the attached drawings are both specified for an sd35 application, even though one is the clamp style and one is the rolled style. Lengths for other units may vary, and in fact there are multiple lengths of stanchions on any single locomotive. These drawings are really more useful for all other dimensions aside from the length. Missing from my files, at least for now, is a drawing of the clamping piece used with types's A and B, as specified in Mick's catalog capture above.
Jim
I've simply marked where the damage is and then made a Chitubox file with the pillars of doom on it, simply imported a column from Autocad, placed accordingly, rinse and repeat then saved.I'm curious about the results of the test with the longer supports. That was my very first thought when you mentioned the idea that prints would sort of correct themselves as they got further from the build plate. If such a solution were effective, it would mean that the model itself wouldn't need to be modified, so no sacrificial edge to remove. That being said, the suggestion to include a crease in the sacrificial edge to locate the cut line and the blade is also a good one . If the extended supports don't work, I will try the sacrificial edge.
Also thanks for the screen cap with the barriers and cab parts together. I too was having a bit of trouble figuring out just how things might be arranged, despite understanding the principle.
Lastly, having the file with the defect location markers is another good idea. I also have the little marks on my film, and they translate through to the surface of parts very clearly. I call it the Princess and the Pea effect. They aren't a problem in the middle of a big flat area, they're easily sanded off. However, mine invariably end up across a detail part though, something like a hinge or door latch, those examples usually go in the bin . I did finally figure out where all the blemishes were located, and recorded their position by grid position. But I often forget exactly where they are, and I also often forget to make sure in Chitubox that I'm looking at the build plate from the right side. Having the markers on the platewouldmight protect me from myself .
Y'all welcome.Mick,
thanks for all explanation, all writen in fluent simond.
Formlabs told us on the Form 1 that the tank didn't use FEP. I never bothered to look on the Form3 but I've just pulled the tank out and it is soft enough to be curved when not supported - I guess that's where the 'soft peel' comes from.
The scallops were the uneven sufaces we got between supports. The rest wil need some thinking about.
