Little progress on the 'Trainset' but provisions have been arriving, some paint and some aggregate, it looks a lot but I suspect it'll soon all go once the brush starts splashing it around.
One of the unknowns was ballast, it's generally accepted that you use the scale below the one you're modelling, not quite sure how that works as any self respecting supplier that sells HO is going to sell HO....by simply rebagging N, or did I miss something
Anyway I picked a couple of grades up and as you'd expect the terminology is not even across brands, fine is not always fine. The Chinchilla sand is for fine dust gravel areas and to generally break up smooth flat areas, the other bags are from WWS, which is more a gaming supplier so I grabbed bags of fine and super fine. I also grabbed some bags and shakers of Woodland scenics, which is much more expensive; not a problem if it does the job.
One thing I did notice with Woodlands is that it's hugely cheaper to buy in bulk, the big shakers are good value for money (comparatively) but not as good as WWS.
I did a quick test of the two most likely looking bags, the rest is easily used up on general scenery, one of the pluses of modeling a railroad in a rocky scenario, plenty of scope for all grades of rock from fist to small house size (1:1).
First up the recommended next scale down Woodland Scenics
fine. It looks okay but to me perhaps a bit small, it's also boringly, uniformly bland.
Second in the ring is WWS
super fine, clearly more granular but oddly (for me) more appealing even if it's a touch over scale. I also prefer the colour blends straight out of the bag.
I suspect the ideal scale is something between the two or perhaps mixing them.
Woodlands also do a medium size blended grey which looks nice, I've grabbed a shaker of that and then can compare all three. Looking at photos it looks to be close to the same grade as WWS Fine so we'll see.
Comparing with 1:1 from the Pacific Northwest it lookks like BNSF use quite a heavy grade for main lines and a smaller grade for sidings, makes perfect sense. A perfect comparison is at Connell the siding is smaller grade than the main behind and the big pile is the coarse stuff too.
Close ups of main line ballast, it's actually surprisingly coarse.
The last is interesting as it shows the fringes are often a smaller grade.
An interesting mix here, not sure what's surrounding the signal base but it looks too regular to be ballast, either side is a smaller grade than the main track.
Finally, perfect use for Chinchilla sand, a lot of the right of way access roads are like this. Note all the modern paraphernalia associated with today's railroads.
Conclusion, I'm hedging toward WWS super fine for the main line, the colour is pretty much perfect too, sadly WWS do not appear to do super fine in any other colours like light grey or buff.
