Okay, moving onward, are we all sitting comfortable, good, here's another episode from the fun filled fiction factory!
Some wag passed comment at the last Sudbury meet that all I'd done was add a few bits to the footplate, visually that's probably true, so on reflection I decided to add something more tangible.
I'm soon coming to the point where the bit that makes it go needs to be added, I already know the smokebox saddle is junk and needs a whole new one so I figured that rather than dive headlong into more scratch building I'd start at the other end with some bits from the kit, I.E. the cab
The cab basically consists of five parts, two sides, a front, a roof and the floor, how hard can it be!
First off they are all in separate parts, the instructions note the sides should be turned in at the rear so that the gap between then when constructed is 49.6 mm (7'1" on the real deal) so some quick math knowing the full width and the final turn in results in a turn in each side of 3.8 mm. This actually went quite well, the first time annealing has worked and the final curves turned out satisfactorily, well chuffed
The next step is to add the sides to the front and make square, okay, hmmm, that's not as easy as it sounds, the front and sides are separate parts and that needs a butt joint along the front edge, albeit with a recessed half etch to help. The problem here is that the recess is in the front face, which means you then trim the excess on the outside faces...right next to some nice half etched rivets.
The recess should be in the cab sides, so that any excess protrudes forward past the front, and can be trimmed back flush with the cab front.....which has no raised detail.
I kind of empathise with this approach, there are two types of cab side, early and later, the rear turn in varies in height, so to save material your supplied with one front and a choice of sides. Having said that, the jig that holds the valances for fitting to the footplate is a throw away item, worse yet all the space in the middle isn't used for any other components.
If you just shifted 30% of the parts off the cab sheet onto the valance support jig, you could then offer both types of cab as one piece items with a half etch fold line for the front corner.
None the less, it is what it is and there will be designed tabs in the kit to align all these individual parts to make a nice square cab, yeah right!
The first photo
All the component parts laid out, tape holds the sides to the front, note two tabs for the front, but zero tabs for the sides, the two side slots in the footplate are for other items.
Adding the assembly to the footplate
I figured the floor would hold the sides the correct width and square
Err no! The cab floor is under size by a good 2 mm, worse yet it's too short length wise and way too narrow at the turn in, rechecking everything to make sure the turn in gap is still 49.6 mm it turns out the cab floor behind the cab is too narrow, basically it looks wrong.
Additional information below.
There is no facility to aid construction in getting all sides square, just ridiculous, and it gets better, note the cab roof behind the engine, what an earth is that supposed to represent? This?
Not even close by a country mile, so not only a new cab floor at the rear end to match the turn in's but a new cab roof as well.
One could put forward that information was scarce when the kit was published (2001), here's a crop from Yeadons book on the A3, published 1990.
The cab floor and turn in is clearly illustrated as is the cab roof, if any one can find a photo of any loco of any period with a roof that matches the kit, please let me know, I've not found one yet.
So in a valiant attempt to show progress and move forward, I've actually gone backward, still, it won't be the first time, nor the last LOL.
Onward!
