Little update on the ROD frames, the first thing you'll notice is that there's no provision for jogging the frames, then you'll notice the frame profile is not quite correct, it should be flat across the top and 2 mm lower. I can see why it's been done as it includes the rear of the splasher but I want those as part of the body section.
The dropped section between the leading and 1st intermediate axle should be straight across as well, the kit does add a piece to the footplate to represent this but the motion bracket just creeps up into this area so you're left with a bit of a gap/juggling between it and the pseudo frames on the footplate, plus there's some oil pots on the inside face that need adding.
Ordinarily I'd solder a blanking plate in but adding the jog will split the joint easily so it was a case of silver soldering, I didn't try to be smart and just flooded it with paste and set to with the big flame. It took a few minutes to clean up and then form the jog, there's still a bit of surface imperfection to dress out but it's workable and onto fitting the axle box guides.
These are formed from 1x1 mm angles each side of the axle box and a 1x2 mm bit across the top to hold the adjustment screw and nut. Over the top of all goes the cosmetic 3D prints.
Modified above, original below.
I accept I'll probably have to cut a new footplate to follow the jogged profile but I feel it's worth as this area and the inside of the frames are quite visible on the finished model. I'll only be using the rear stay and part of the front one (modified) the rest will be new etched ones with slightly better profiles and fixing flanges etc.
