Little bit of bench time today on the Garratt, brass gets really tarnished if you put it down for a while......
Couple of shots before the replacement parts.
Cab.
Boiler frame/brake hanger stay.
New cab sides, rear sheet just plonked on for photos, the cab rear sheet needs a big circular hole adding in, the kit would have you add a simple circular sheet strip to the correct diameter to the rear outside face....and leave the middle solid....not happening.
A bit better I think, should look okay once the rear wall is secured, door added and roof fitted.
New boiler frame/brake hanger stay.
The smoke box base is a disaster, why there are two slots cut in the wrapper I do not know, it'll need some sort of 3D casting printed down there; I'll need to finish the front engine frames with at least wheels to check clearances before working something up.
Cab.
![IMG_9234.jpg IMG_9234.jpg](https://www.westernthunder.co.uk/data/attachments/128/128984-070d8ced38e81fdbd0d2982cadf6320d.jpg)
![IMG_9235.jpg IMG_9235.jpg](https://www.westernthunder.co.uk/data/attachments/128/128985-3cf34d3b98edaaf4537219d1aa0850c2.jpg)
![IMG_9238.jpg IMG_9238.jpg](https://www.westernthunder.co.uk/data/attachments/128/128986-f910e97bb9cdcb4f84e8965495db4f6d.jpg)
![IMG_9241.jpg IMG_9241.jpg](https://www.westernthunder.co.uk/data/attachments/128/128989-23559291f3bb6fdfcccf9412c85c7e85.jpg)
![IMG_9239.jpg IMG_9239.jpg](https://www.westernthunder.co.uk/data/attachments/128/128987-676ad5846a67437e32512052c5f872a6.jpg)
![IMG_9240.jpg IMG_9240.jpg](https://www.westernthunder.co.uk/data/attachments/128/128988-1800e760a7fbff266c0e75c922513c63.jpg)
