That said, there’s a go-to photo from the ‘Disused’ site which inspires and is located in the same area on which I’m basing Monks, and although it’s rare and extreme, it gives me some reassurance:
This is a very interesting photo in it's own right but also appears to cover both aspects of the ballasting of sleeper ends. The Class 33 is approaching a point which has sleeper ends around the tie-bar covered whilst the other ends are clear. The point on the parallel road has all sleepers proud of the ballast. It does really create a situation where one must either do in depth research to be totally accurate or contrive to create a scene that personally satisfies oneself. I happily confess that the latter is my preference.
As you said to me elsewhere, there's a prototype for everything which can be constantly proved by photographic evidence. That is one of the other reasons that I love this great hobby !
Bless you, Roger
Roger
Evening Jonte.
Firstly, no forbearance is required certainly not on my part. It's always a pleasure to pop in and see how things are going. Therefore, nice as it is to receive thanks, rest assured, none are required.
Ballasting is a big of a dark art to me but one which I seem to muddle through. I regard it as a chore and something to get through but it takes me forever.
It seems to take ages to lay, tamp and brush the ballast into place. I have used a few types over the four layouts, the last being Woodland Scenics fine cinders on Sheep Dip as below.
I tend to use less ballast around the tiebars etc knowing that I will be glueing around moving parts.........which funnily enough, I still want to move after the glue has set.
I then glue it in place using the usual PVA/water/ Fairy mix applied with an syringe to ballast already dampened using a fine mist of plain water. I make sure the tie bar area is wet to draw in the PVA mixture.
If I had to guess at ratios and I do have to guess, it would be one part PVA to two parts water and a liberal squirt of Fairy.
By now its pretty wet and I just leave it over night........sometimes longer. It takes as long as it takes to dry.
And it sticks........hard. To date very little if any has come loose despite much moving and jiggling about to and from exhibitions.
I also use this mix to secure the ash I use in the yards as the ground surface and have also used this to drop into the track bed to secure static grass and weedy stuff.
I'm no ballasting guru but this is what works for me.
I use latex, watered down, rather than PVA, which gives granite a green tinge. Not an issue if you’re using non-granite, or painting it.
The other thing that latex does is creep very enthusiastically by capillary action. If you pre-wet the ballast with water & washing up liquid (I find only a drop needed), then drip the watered latex in, you’ll see it scoosh through the gaps between the grains in a very satisfying manner!
Atb
No!
this stuff. Tenner for 1.5 kg from Screwfix
Atb
Pre wetting the ballast also works well for the watered down PVA method. I use one of those kitchen disinfectant spray bottles (once the contents have been used of course) and fill with water and a drop of washing up liquid.
Mist over the track and ballast at a distance to avoid disturbing the ballast, wait a while for it to soak through, then apply the watered down PVA mix in drops. It quickly soaks in without the balling up that occurs when applied to dry ballast.
