Crikey! Things move on apace now!
I set about glazing the D94. As I mentioned before, I had a cunning plan to use the kit glazing to make templates to help cut the glass microscope slides.
Each window shape was measured up to be slightly under the actual size I needed and marked out on some graph paper. I used some masking tape to act as a datum. Working with glass is a pain. It's all but invisible! It also takes a while to get the knack with the carbide tip, but happily my wastage rate was relatively low.
I researched what other people use to fix the glass in place, and it seems to fall back on the good old Kristal Klear, so that's what I used.
Here's the first completed side. Those reflections are the business.
I had pondered how to replicate the hammered glass used in the lavatory windows. I'd seen several examples where people had used plastic report covers to great effect. I had a used ring binder pocket, and here's the result glued behind the glass. I think it looks about right.
With both sides of the D94 glazed, and the van section window bars done, it seemed churlish not to assemble the sides and ends to the floor. Call it a morale booster if you like, but I can now say I have actually finished one of the triplets - aside from a little bit of QC to sort out.
