Thanks Richard! Yes, I reckon by the end of the next week they'll be close to completion. Mind you, I keep saying things like that, only to miss such self-imposed deadlines by a country mile!
Since about 10 this morning I have been lining and lettering one side.
Actually, that's not too bad, and it's better to take your time over such things. I'm using Fox waterslide for the lining and lettering. The BR livery lining is deceptively simple, yet takes a deal of time because of the nature of the coaches to which it is applied. Demarcating the cream from crimson is black and gold lining.
The gold is on the cream side of the line. Um, gold on the crimson side...
Here's the workbench setup for transfers. The magnifying lamp is probably the single best investment in modelling tools I've made. Even on a bright day like today, working under the magnifier is the only way I can see what I'm doing! Perhaps I should speak to my optician and get some new specs that let me focus closer than my outstretched arm.
Other tools in use are a fine sable brush, a pencil, some fine tweezers and a scalpel with ready supply of sharp 10A blades.
At the back you can see the jury-rigged water bath. Fox recommend warm water. Not cold, not boiling, but warm. The problem is how the deuce do you keep the water warm while you're working at applying transfers over a period of some hours?
My answer is an aluminium foil try sat over a tea light. The only problem is the water gets hot locally above the flame, and doesn't seem to set up any convection currents to mix it nicely. I stir it occasionally to spread the warmth about a bit.
It's just plain tap water, with a drop of washing-up liquid as recommended by Fox. As you know, the coach sides have been treated to a coat of gloss varnish, also recommended by the manufacturer.
Because the sides are broken up by doors, I opted to trim lengths of the lining transfer to fit each panel. It's easier than trying to bed the transfer down into the gaps. As I completed the first set of lining along the top edge of the corridor side of the C64, I reckoned I could just as easily - and more quickly, to be honest - done the lining with the bow pen. I'll complete this coach with the transfers, because while it takes time it is actually quite relaxing in a funny kind of way. The other two coach I may well line with paint. I'll decide that later.
(The technique would be to line the gold, which would actually be a buff colour as you can't see it's gold anyway. Once that is dry, black would be lined over it to leave the thinner "gold". Sounds simple, and it is really. Also a lot quicker than piecing together fragments of transfer...)
Anyway, having trimmed a section of lining and dunked it for some seconds, I wetted the area where it was to be placed using the brush loaded with water. Picking the transfer paper out of the tray with tweezers, I teased the transfer from its backing onto the model. There followed a little while of persuading the lining to sit where I wanted it.
Once happy with the location, a clean cotton bud is gently pressed over the transfer to soak up excess water. If the gods are with me, the transfer beds down nicely. If they are against me, the transfer comes away with the cotton bud, and I have to start again with a fresh strip. You can't really reseat the things once the gum has soaked away, so it's best to start over.
Fox helpfully provide guidelines attached below each character on their numbering sheets. It's a nice idea, but I found in practice attempting to trim the carrier away ended up with the number moving anyway. I ended up trimming the number out and aligning things by eye - although I stuck a strip of masking tape just below where I thought the baseline ought to be as an aid. I think this running number is a little high, and could be shifted to the right a gnat's to allow for the commode handle on its left. What does the team think?
Once lettering and lining has been done, I shall set each side aside for 24 hours before I try to put the protective satin varnish on top.
