Heather Kay
No apologies required, Steph. It's all part of the fun of trying to interpret photos in order to get the details as correct as possible.
I have completed the ends for all three coaches now. I have to admit I have reservations about the JLTRT rubber bellows mouldings. They are variable in quality, and inconsistent in dimensions.
To aid with constructing the gangways, I came up with the notion of making a balsa former to fit into the bellows to hold them to shape while the etched plates are attached.
It sort of worked. I say "sort of" because of the variation in the bellows mouldings, but the idea is sound. Initially, I made the mistake of making the former a really tight fit, the idea being to hold the bellows to the actual size of the etched plate apertures. The problem here would be removing the former without causing damage to things. I trimmed them down so they were a reasonably sliding fit, enough to support the bellows but small enough to allow for removal after the glue had set.
There is a back plate, which fits to the coach end, and a front plate which represents the connecting surface. The back plate has an etched rebate, into which the bellows fits, fairly neatly. The front plate, however, has to sit over the bellows. This means the gluing surface is effectively the edge of the etch itself. I am not terribly happy with this, but providing the client isn't clumsy they should survive most handling events.
Dimensional accuracy of the rubber bellows is quite poor. One moulding may be a good fit, while the second from the same pack may be short in height. The consequence is gaps appear at the top and/or bottom.
Theoretically, it should be possible to stretch the moulding and clamp it while the glue grabs. In practice, this isn't a workable solution, for various reasons. The moulding likes to try and return to its original size, and there is a risk it will distort the outer plate when it does so. The mechanical strength of gluing the thin edge of the etch is also questionable.
Here you can see the gaps around the bellows. I am hoping the gaps around the top will be masked by the canvas cover I'll add after painting. The gaps around the sides may be hidden by the painting, and the gap at the bottom could be masked by a floor plate, which I could extend outwards slightly.
Moulding distortion, which is all but impossible to rectify by gluing and clamping. It's not that I can get better bellows. Each pair I've received from JLTRT has exhibited the same issue. I'm not sure if there's a better supplier of such things. How do the CPL ones match up?
You could drive a bus through that.
Anyway, here's a pair ready to stick to the coach end. Aligning the gangways on the end could be a bit hit and miss. As it turned out, I had decided to trace around the inside edge of the back plate onto the coach end, because I was adding door handle detail to it. The traced outline allowed me to locate and glue the finished gangways in a repeatable fashion.
Finally, for now, the JLTRT steps and lamp brackets are designed to be glued into moulded slots. The steps each needed a clean up with a fine file to make a nice fit (twenty per coach...
It's a wonder I'm still sane). The lamp brackets wouldn't last five minutes in service. I took the precaution of soldering a short length of 0.45mm brass wire to each bracket so it fitted into a 0.5mm hole drilled next to the slot. The CPL versions fold up with a nice fixing plate - I know this because I used them on the D94. If you recall, the D94 had some issues with the etches, such as solid compartment windows and missing end steps and lamp brackets.
Notice anything else missing? There are no representations of the grab handle fixings. I considered adding this detail, but the diagonal handle doesn't leave a lot of space near the outer edge. As there's plenty of clutter on the ends, I felt they wouldn't really be missed.
I suppose it's time to get the airbrush out.
