Heather Kay
I'm pleased my thoughts on the ventilator patterns on these early Collett coaches has caused so much interest!
Today, after yesterday's jaunt to Railex, I've got back to the nitty-gritty of the underframes. I began to work on one of the dynamos, carefully drilling out the holes to freely hang it from the bracket as is my wont, when the worst happened. The whitemetal parted...
The obvious thing would be to bung the 0.7mm wire in and glue it all up solid. However, at this stage, I don't know the angle of the dangle, which is why I like to have it hinged in the first place. What to do, apart from put my head in my hands and sob?
Well, not having a well-stocked spares bin of JLTRT castings - yet - I gave it some thought. I could make a replacement bracket. A quick measure up, and almost literally a back-of-the-envelope sketch followed.
I found some suitable scrap etch, just about perfect for the job. The remains of the cast bracket were filed from the dynamo.
This was then carefully drilled through with a 0.5mm bit. On the squiff, as usual.
Then, on to the bracket itself. After some careful - for me - marking out, a bit of filing and drilling and application of the hotting stick, the result was quite acceptable.
And here it all is, assembled.
I always seem to end up with carefully marked out and drilled holes "on the squiff".
Still, it does the job.
Now, where was I before that diversion? Ah, yes, underframes. Time to bend some etches and get the trusses sorted out, then to do the whole thing again for the other underframe. What have you planned for your bank holiday weekend?
