2-Bil
Hi Chris
3''RWPs measured 6 foot from the top of the collar to the base of the pipe which was beaded.3''RWPs were only ever cast in 6 foot lengths were very thin walled,lightweight and when cut you could see more often than not how unevenly they were cast.The London Cast Company used to mould L.C.C.on their rainwater pipe collars
Respects Brian W
NHY 581
This evening I had a revelation that solved this issue and a concern that the 3d pints aren't that resilient and can easily break or snap.
Sorted.
3d pints can also be knocked, spilt or dropped, obviously unlikely in our case as it's not in the glass long enough but still a flogging offence in certain parts of Ireland so best avoided.
Hi Chris
Respects Brian W
Thanks Brian, very useful. I do need to add a joint midway along the length, it's currently more a test of getting the brackets to fit.
Did the 4" pipes also come in 6' lengths?
Just realised that I've not mentioned the source of the 3d printed chimney pots....
Richard Slate, Mudmagnet on RMweb, is an old friend from our days on the exhibition circuit in the SW. He's got his own company "Mudmagnet Models" which started as making buildings and layouts for people. In recent years he's moved into 3d printing.
The pots were a special commission, which I'm sure he'd be happy printing for others, and should satisfy my chimney pot needs for the entire layout.
I collected these from him at the Stafford show late last year. Amazing what can be produced these days.
2-Bil
Hi Simon
Re post 2765
3"outside in this weather is, disappointingly, about right.....
Chris
Re post2767
4"soil pipes came in 6 foot lengths too.Joints were sealed with yarn then lead.4'Soil pipes as opposed to RWPs were a heavier casting without holderbats
Brian W
NHY 581
Richard will be peddling his wares at the SWAG Day at Staplegrove Village Hall in April. Pencarrot will also be there with his Big Boys Buildings.
Come along, pick up some chimney pots and spend the day chatting about downpipes.
By God we know how to have fun.
JimG
That brings back memories from a long time ago. As a teenager, during school holidays, I worked as a plumber's mate in the local distillery and one of the jobs I was taught was roping and caulking cast iron pipes - not 3" or 4" pipes but much larger - probably 10" to 12" diameter. The acid test was when the joint was put under pressure - I think I remember that I had to re-caulk the one I did - and I got an earful from the foreman. :)
Jim.
Well fair dues to Modelu, I dropped them a line and it transpires that the pack of 3" holderbats I had was an early print. It's been subsequently amended so that the hole is 2mm (the OD of the pipe) and a new pack has been added to the order I placed at the weekend. Excellent customer service.
They appeared on his thread in the other place, I can't remember whether it was yesterday or today.
