Osgood
While you wait for a reply from PC, FWIW I obtained a DeWalt DW088CG laser level - a green light horizontal / vertical type, mainly for outside work (drainage, ditches, et al).
Nice unit, plenty of mounting options (magnetic etc) - stuff inside is gimbal-mounted so can just plonk the case down on a reasonably flat surface.
Red light laser levels can be a fair bit cheaper and fine for internal work, but for outside use green is much easier to see outside, and over much greater distances (check out red v. green laser levels online).
I was hoping for a longer visible range but you find workarounds - even so you might find yourself setting out at dawn or dusk!
This unit emits a horizontal datum line 55mm off the base.
